Normal Topic Binding Appointment ItemModifying event (and sending the appointment as CommandParameter) (Read 2478 times)
gilav
May 15th, 2018 at 3:10pm
I binded the event to a command successfully, but when using CommandParameter="{Binding}" , I get the whole DataContext of the view on the command function and not the appointment I changed.
how can I send the changed appointment to the CommandParameter?
Im breaking my head over this.
Thank you in advance ! Smiley
EDIT:
I send the Element of the whole Calendar, and extracted the ItemSelection from that.
I would wish if it would send it correctly with normal binding, but that works too
Online
Re: Binding Appointment ItemModifying event (and sending the appointment as CommandParameter)
Reply #1 - May 16th, 2018 at 7:10am
You could translate from event handlers to commands using attached properties -
public class CalendarCommands
	static public ICommand GetItemModifyingCommand(DependencyObject obj)
		return (ICommand)obj.GetValue(ItemModifyingCommandProperty);
	static public void SetItemModifyingCommand(DependencyObject obj, ICommand value)
		obj.SetValue(ItemModifyingCommandProperty, value);
	public static DependencyProperty ItemModifyingCommandProperty =
		DependencyProperty.RegisterAttached(
			"ItemModifyingCommand",
			typeof (ICommand),
			typeof (CalendarCommands),
			new PropertyMetadata(CalendarChanged));
	static void CalendarChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
		var calendar = (Calendar)d;
		calendar.ItemModifying += (s, args) =>
			var cmd = GetItemModifyingCommand(d);
			if (cmd != null)
				cmd.Execute(args);
and then bind the attached command to a command property of your window or view-model -
<planner:Calendar Name="calendar"
    local:CalendarCommands.ItemModifyingCommand=
        "{Binding MyCommand, RelativeSource={RelativeSource Mode=FindAncestor, AncestorType=local:Window1}}"
then the parameter specified will be the respective event-args object -
public class MyCommand : ICommand
	public void Execute(object parameter)
		var args = (ItemModifyConfirmEventArgs)parameter;
		Debug.WriteLine(args.Item.HeaderText);
