Normal Topic JDiagram Drag Selection Issue (Read 6232 times)
Jasef
Jun 5th, 2013 at 10:11pm
I seem to have noticed there are clipping issues with drag selection. Very subtle bug.
Bug seems to persist since JDiagram 3.4 to 4.0.1 (Couldn't test any further back)
To reproduce what I see:
> Select a bunch of nodes. (Attachment Step1.png)
> Drag select a different bunch of nodes. (Attachment Step2.png)
Now you should see the selection handles on the nodes you have drag selected.
But also see (partial) selection handles on the original selection of nodes (As what is seen in Attachment Step2.png)
Hovering over the original nodes will remove these partial handles.
If you cannot reproduce, you may need to separate out the nodes between the groups of selections you are making.
The nodes are custom extended objects of TableNode.
I have only overriden the drawHandles method recently and only handles the shape of the handle, so that shouldn't affect what's going on with this bug.
Also tested on basic ShapeNode objects with the same result.
Fix-Priority: Low
Regards.
Re: JDiagram Drag Selection Issue
Reply #1 - Jun 18th, 2013 at 2:27pm
This version should fix that:
https://mindfusion.eu/_beta/JDiagram402.zip
If you build from source code, you could add a repaint call before clearSelection in Selection.completeCreate:
protected void completeCreate(Point2D end)
	super.completeCreate(end);
	getParent().repaint(getRepaintRect(true));
	clearSelection();
Jasef
Reply #2 - Jun 23rd, 2013 at 11:04pm
Works perfectly. (Building from source)
Thanks!
