Normal Topic Controlling the calendars monthrange via keyboard (Read 4424 times)
mw
Jun 11th, 2013 at 8:09am
Is there any way to control ( or navigate inside the monthrange) the selection of cells inside the monthrange via keyboard? I couldn't find any settings for this option.
Maurice
Re: Controlling the calendars monthrange via keyboard
Reply #1 - Jun 11th, 2013 at 8:34am
At this time there is no built-in support for selection navigation using the keyboard in WpfPlanner. You can handle the appropriate Key* event of the Calendar control and perform the necessary selection adjustments through the Calendar.Selection object manually. For example, the following PreviewKeyDown event handler can be used to modify the selection by using the Left and Right arrow keys:
if (e.Key == Key.Left || e.Key == Key.Right)
	if (_calendar.Selection.IsEmpty)
		return;
	e.Handled = true;
	if (e.Key == Key.Left)
		DateTime first = _calendar.Selection.Ranges[0];
		first = first.AddDays(-1);
		_calendar.Selection.Set(first);
	else
		DateTime last = _calendar.Selection.Ranges[_calendar.Selection.Ranges.Count - 2];
		last = last.AddDays(1);
		_calendar.Selection.Set(last);
mw
Reply #2 - Jun 11th, 2013 at 8:41am
Thank you. I'll implement the handling for the events on my own then. Thank's for the example Smiley.
Maybe in future versions of the control it will be implemented  Grin
Maurice
