Normal Topic System.ArgumentException in LinkRouter.RouteLinks() (Read 7764 times)
j poz
Aug 12th, 2013 at 2:23pm
When calling TheFlowChart.LinkRouter.RouteLinks(linkCollection) I am sometimes seeing the following exception (with stack trace):
Quote:
System.ArgumentException: Unable to sort because the IComparer.Compare() method returns inconsistent results. Either a value does not compare equal to itself, or one value repeatedly compared to another value yields different results. IComparer: 'MindFusion.Diagramming.NeighborComparer'.
at System.Collections.Generic.IntrospectiveSortUtilities.ThrowOrIgnoreBadComparer(O
bject comparer)
at System.Collections.Generic.ArraySortHelper`1.Sort(T[] keys, Int32 index, Int32 length, IComparer`1 comparer)
at System.Collections.Generic.List`1.Sort(Int32 index, Int32 count, IComparer`1 comparer)
at MindFusion.Diagramming.QuickRouter.SplitPaths(List`1 paths, Boolean horizontal)
at MindFusion.Diagramming.QuickRouter.RouteLinks(DiagramLinkCollection links)
at CompanyGuiToolkit.Document.View.RouteContainerLinks(ContainerNode n, Boolean bFromArrowChange) in s:\Company\CompanyGuiToolkit\Document\View.cs:line 550
at CompanyGuiToolkit.Document.View.m_flowChart_NodeModifying(Object sender, NodeValidationEventArgs e) in s:\Company\CompanyGuiToolkit\Document\View.cs:line 4101
at MindFusion.Diagramming.Diagram.RaiseModifying(DiagramItem item, InteractionState ist, Boolean starting)
at MindFusion.Diagramming.DiagramNode.AllowModify(PointF current, InteractionState ist)
at MindFusion.Diagramming.InteractionState.ValidateAndSetCursor(PointF point, Diagram diagram)
at MindFusion.Diagramming.WinForms.Behaviors.BehaviorBase.OnMouseMove(Point mousePosition)
at MindFusion.Diagramming.WinForms.DiagramView.OnMouseMove(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseMove(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Re: System.ArgumentException in LinkRouter.RouteLinks()
Reply #1 - Aug 13th, 2013 at 5:55pm
I think that was a breaking change in .NET 4.5, and our developers rewrote NeighborComparer for one of the recent Flowchart.NET releases. You could either build for older .NET versions, upgrade to latest version of the control, or I could send you our current NeighborComparer code if you have the source code.
j poz
Reply #2 - Aug 13th, 2013 at 8:12pm
We are going to upgrade to the current beta, once it is out of beta, or a version after that. If the fix is in there we should be okay..
tr
Reply #3 - Mar 19th, 2015 at 7:48pm
Could you send the code of the update NeighborComparer ? That would be very helpful.
Reply #4 - Mar 20th, 2015 at 8:57am
This offer was to customer on active maintenance, your company will need to renew support subscription if you expect support and patches. We implemented QuickRouter 6-7 years ago specifically for you guys (documented in this thread), but we can't really afford providing you with free support forever after Smiley
tr
Reply #5 - Mar 20th, 2015 at 3:52pm
Makes sense Smiley due to internal miscommunication, I have trouble knowing what our agreement is or was...
Théo
tr
Reply #6 - Mar 24th, 2015 at 2:38pm
Last questions:
- in which version has this been fixed ? We're using 5.6.1, but I've been told we had v5.6.3 somewhere.
- If that's not enough, are you willing to give us any hint to fix it ourselves ? Sadly, I think I won't be able to convince people to spend money...we're too busy giving it to "this big company holding the 3d modeling/animation monopoly" -_-
Reply #7 - Mar 24th, 2015 at 4:04pm
I think it was fixed in v6.0.4. Support and upgrades for one developer would cost you something like $250 for an year. But ok, if you are in such bad situation we will give you latest comparer code as one-time service, you can find it on private messages page.
