Hot Topic (More than 10 Replies) InPlaceEditing not showing textbox automatically (Read 9133 times)
Vincent
Nov 6th, 2013 at 11:34am
In my Diagram class I have set AllowInplaceEdit = True. This does allow me to edit the Text in nodes but it doesn't show a textfield when I double click the node. How can I fix this?
Notes:
- The Diagram is in a ScrollViewer and I have set ScrollViewer.Focusable = False
- The nodes are custom nodes with override to Draw()
Thanks in advance!
Vincent
Re: InPlaceEditing not showing textbox automatically
Reply #1 - Nov 6th, 2013 at 12:23pm
What do you mean by "This does allow me to edit the Text in nodes but when it doesn't show a textfield when I double click the node" - does it show the textbox only for some nodes?
Vincent
Reply #2 - Nov 6th, 2013 at 12:30pm
When I double click a node, the appearance of the node (with or without text) stays the same. When I type something and click outside the node's bounds the text appears.
Reply #3 - Nov 6th, 2013 at 1:46pm
The textbox shows correctly if I enable AllowInplaceEdit in the project you attached to this thread:
http://mindfusion.eu/Forum/YaBB.pl?num=1382359395
If you still keep the MeasureOverride from http://mindfusion.eu/Forum/YaBB.pl?num=1383232837, remove it. It's not correct because it does not propagate to child elements, including the in-place TextBox. Or otherwise add a call to base to process the children too.
Vincent
Reply #4 - Nov 6th, 2013 at 2:13pm
I downloaded the project you mentioned and tried it but it doesn't seem to work Huh
In my project I didn't implement the measure override.
When I set MagnifierEnabled to true it does seem to work for some reason. However, when I do set that property I can't access the ContextMenu of the nodes. How can I get the textfield without setting the MagnifierEnabled? I added my project as an attachment.
Thanks in advance!
Vincent
DragDropExample_-_Copy_003.zip (Attachment deleted)
Reply #5 - Nov 7th, 2013 at 7:51am
The TextBox appears as expected when I run this project. In case it doesn't show for you because of incomplete WPF layout phase, try calling diagram.UpdateLayout or e.TextBox.UpdateLayout from the EnterInplaceEditMode event handler.
Vincent
Reply #6 - Nov 7th, 2013 at 2:01pm
Doesn't work unfortunately. My code is:
private void MC_Diagram_EnterInplaceEditMode(object sender, InPlaceEditEventArgs e)
            e.TextBox.UpdateLayout();
            this.UpdateLayout();
Reply #7 - Nov 7th, 2013 at 4:17pm
What version of the control are you using?
Vincent
Reply #8 - Nov 8th, 2013 at 11:49am
2012.R2
Reply #9 - Nov 8th, 2013 at 12:21pm
That's version 3.0.1 of the diagramming.dll if you look in the reference property window, right? Your project works for me if I compile it with 3.0.1 too though.
Could you check if you can see the edit box in the installed SequenceDiagram.exe sample from the StartMenu/Wpf Pack/Diagram/Samples shortcut? If it’s ok, check if it still works if you compile the sample on your system from the installed VS solution.
Vincent
Reply #10 - Nov 8th, 2013 at 3:04pm
The sample project works when I compile it in the VS installed on my computer. I guess it must be something in my project..  Huh
Reply #11 - Nov 8th, 2013 at 4:15pm
Could you upload somewhere the zipped bin/debug folder from your compiled DragDropExample project, or send it to our support email address?
Reply #12 - Nov 11th, 2013 at 9:58am
We tried it on several systems, and apparently the textbox does not show when running under .NET 4.5 on Windows 8. .NET 4.5 under Windows 7 is ok. If we rebuild the sample with .NET 3.5 as target framework (using respective .NET 3.5 diagram assemblies), it starts to work on 8 too. Our developers will investigate this in the next days, for the time being you can build for .NET 3.5.
Vincent
Reply #13 - Nov 11th, 2013 at 2:42pm
Ahh, I was running .NET 4.5 on Windows 8 indeed. And changing the target framework to .NET 3.5 fixed it as well. Thanks for the info! Smiley
Vincent
Reply #14 - Dec 18th, 2013 at 7:45am
With this version the edit control should show correctly under .NET 4.5 + Windows 8 too:
https://mindfusion.eu/_beta/wpfdiag304.zip
