Normal Topic Show text at the end side of link (Read 2539 times)
Ada
Mar 13th, 2014 at 8:58pm
I want to show link.text on the end of the link, i.e, on the arrow side. But I can't do it with all the available textstyle. I also tried the linkLabel with no luck.
Would you please help me with that.
Thanks.
Ada
Re: Show text at the end side of link
Reply #1 - Mar 14th, 2014 at 8:26am
You can implement that using a LinkLabel like this:
var endLabel = new LinkLabel
    Text = "this is the end",
    RelativeTo = RelativeToLink.ControlPoint,
    Index = -1,
    AutoArrange = true
link.AddLabel(endLabel);
Negative Index value signifies a control point relative to the last one, where -1 is the last point. Set AutoArrange to automatically adjust the label so that it does not overlap nodes.
Alternatively, with AutoArrange disabled you could set label's position manually via the HorizontalOffset and VerticalOffset properties if you need it placed at a specific position. Offsets are relative to the point specified via Index and RelativeTo, e.g. the link's end point in this case.
Ada
Reply #2 - Apr 7th, 2014 at 9:18pm
Thanks Stoyan,
That is exactly what I need.
