Page Index Toggle Pages: 1 2 [3]  Send TopicPrint
Very Hot Topic (More than 25 Replies) customize view in monthly calendar (Read 33306 times)
Re: customize view in monthly calendar
Reply #30 - Apr 4th, 2014 at 7:11am
The updated sample demonstrates a way to do it using triggers:
https://mindfusion.eu/_samples/_sample_CustomMonthCalendar8.zip
vijayalakshmi
Reply #31 - Apr 21st, 2014 at 5:25am
Hi Meppy,
In the snapshot attached below,
the calendar panel in the left has to display yellow color for the month button click event and simultaneously the month calendar has to be displayed in the right side.
In the current Custom month Calendar file which you provided, the navigation on the left calendar is not working fine with navigation on right calendar.
Please help me fixing this..
Waiting for your response.
Vij Smiley
vijayalakshmi
Reply #32 - Apr 21st, 2014 at 8:22am
Customizing calendar on left exactly as in snapshot is my priority...
I wana assign colors to current month days exactly as in snapshot...
Please help me on this...
Waiting for your response...
Viji Smiley
Reply #33 - Apr 21st, 2014 at 11:16am
To customize the Background/Foreground of the selected cells in a SingleMonth view, set the respective properties of the Calendar.MonthSettings.SelectedElementsHeaderStyle. For example, to make the Background and Foreground orange and black respectively, use the following code:
calendar2.MonthSettings.SelectedElementsHeaderStyle.Background = new SolidColorBrush(Color.FromArgb(255, 251, 200, 79));
calendar2.MonthSettings.SelectedElementsHeaderStyle.Foreground = Brushes.Black;
What do you mean by "the navigation on the left calendar is not working fine with navigation on right calendar."? In my sample the two calendars appear to be synchronized, that is, navigating in one updates the other and vice versa.
vijayalakshmi
Reply #34 - Apr 22nd, 2014 at 8:19am
Hi Meppy,
Thank you for the color customization code which you shared ...
I need to display current date in navigation control along with month and year. You suggested me to change string format to dd MMMM yyyy format..
But after running application, I am getting 01 Apr 2014 instead of current date i.e., 22 Apr 2014
One more thing is week range setting Apr 16 - Apr 22 2014.
Can you please share the code for this.
waiting for your response.
Thanks & Regards,
Viji Smiley
vijayalakshmi
Reply #35 - Apr 22nd, 2014 at 10:15am
Hi Meppy,
The week range is of high priority for me. Please help me on this.
Please find the snapshot attached.
Viji Smiley
Reply #36 - Apr 22nd, 2014 at 10:44am
You can set the NavigationControl.Header property to whatever you need to be displayed in the navigation header. You can do this by binding the property in XAML or by manually setting it in the code behind, the same way you would do with any other property.
Reply #37 - Apr 23rd, 2014 at 5:54am
Try the following:
navigationControl.Header = DateTime.Today.ToString("dd MMMM yyyy");
Alternatively, define a dependency property of type DateTime, say CurrentDate, on your window, assign DateTime.Today to this property and bind to it in XAML:
<l:NavigationControl Header="{Binding Path=CurrentDate, RelativeSource={RelativeSource AncestorType=l:MainWindow}, StringFormat='dd MMMM yyyy'}">
Setting the header in code might be more convenient if you need to display complex texts, such as "Apr 16 - Apr 22 2014".
vijayalakshmi
Reply #38 - Apr 23rd, 2014 at 7:31am
Hi Meppy,
The code which you gave ,navigationControl.Header = DateTime.Today.ToString("dd MMMM yyyy");
I must add this in MainWindow.xaml.cs or NavigationControl.cs ???
In the both the files I am getting an error.
Please can you provide the complete month calendar solution with this update???
Waiting for your reply...
Viji Smiley
Reply #39 - Apr 23rd, 2014 at 10:46am
This sample demonstrates both approaches:
https://mindfusion.eu/_samples/_sample_CustomMonthCalendar9.zip
