Normal Topic DiagramNode.MoveWith method dissapeared? (Read 5993 times)
Mikael P
Apr 14th, 2014 at 8:31am
We have a solution that we're trying to upgrade from Silverlight 4 to 5 (i.e. replacing the mindfusion dlls). However, we've stumbled upon a problem.
The method DiagramNode.MoveWith seem to have been replaced/removed to something else but we can't find anything about this in the API (where it still seems like the DiagramNode.MoveWith is valid) or in the forum.
Is there a new method to use and where can we find it?
E.g. selectedNode.MoveWith(0, yTopValue - selectedNode.Bounds.Top);
Thanks in advance!
//Mikael
Re: DiagramNode.MoveWith method dissapeared?
Reply #1 - Apr 14th, 2014 at 8:41am
You can set the Bounds property instead, or call the SetBounds method:
var bounds = selectedNode.Bounds;
bounds = Utilities.Offset(bounds, 0, yTopValue - bounds.Top);
selectedNode.SetBounds(bounds, true);
Mikael P
Reply #2 - Apr 14th, 2014 at 8:55am
Hi Stoyo,
I'll check it out! Thanks for your fast response!
Kind regards
//Mikael
