Normal Topic ResizeToFitItems(), ModifyItemCmd and undo (Read 1685 times)
j poz
May 14th, 2014 at 9:05pm
I am using a ModifyItemCmd to record the changes made to a shape node.
At the same time, Diagram.ResizeToFitItems() is being called to make sure the view size correctly matches the bounds of the items on it.
However, when I do an undo, ResizeToFitItems() is not accounted for and the scrollbars do not change.
Is there a way to easily wrap this into the undo composite stack?
Or is the only way to create a custom undo command?
Re: ResizeToFitItems(), ModifyItemCmd and undo
Reply #1 - May 15th, 2014 at 7:14am
You can find a custom command that does that here:
http://mindfusion.eu/Forum/YaBB.pl?num=1290792836/6#6
Alternatively, you could call ResizeToFitItems from ActionUndone and ActionRedone event handlers.
