Normal Topic Custom LinkTextStyle ? (Read 2311 times)
Rich Cassell
Jul 16th, 2014 at 11:13am
I'm using labels on our links and have been trying to find a way of displaying information in an efficient way. I've been through the enumeration entries for LinkTextStyle and none really cater for what we need and I wondered how simple it would be to mimic the enumeration and layout the labels in my own way?
Ideally, what i'm after is a sort of "LinkTextStyle.OverLastSegment" option, which obviously isn't available. Also, some of our labels could be quite long so I wondered how i'd get multiple lines of text?
If i can't do it this way, would it perhaps be possible for me to create a borderless, transparent node that i can then use as a label? That way i am at least in control over where it is etc!
Any help or pointers will be appreciated.
Thanks!
Rich  Smiley
Re: Custom LinkTextStyle ?
Reply #1 - Jul 16th, 2014 at 11:21am
Instead of setting Text, you could use a LinkLabel attached to last segment:
private void diagram_LinkCreated(object sender, LinkEventArgs e)
	var label = e.Link.AddLabel("long label at last segment");
	label.RelativeTo = RelativeToLink.Segment;
	label.Index = -1; // last segment
	label.AutoArrange = true;
Rich Cassell
Reply #2 - Jul 16th, 2014 at 2:43pm
Hi Stoyan,
That's great. Works a treat! Thanks muchly Smiley
Rich
