Normal Topic How to make the OrthogonalRouter work? (Read 3931 times)
mihai
Jul 28th, 2014 at 9:33am
I'm trying to use the OrthogonalRouter after manually positioning the nodes, but it's not doing anything. I have used to do this with the WinForms version, and that worked.
Most of the nodes are placed in containers, so I've tried to set KeepGroupLayout to false, but that didn't help. I've also toggled the IgnoreLayout on links, but nothing changed.
Any hints would be highly appreciated.
-Mihai
PS: Is there a sample app in the installer to demo the OrthogonalRouter?
Re: How to make the OrthogonalRouter work?
Reply #1 - Jul 28th, 2014 at 10:28am
I think we made KeepGroupLayout always enabled for containers at some point, which will prevent OrthogonalRouter from finding paths inside them. Try excluding them like this instead of setting IgnoreLayout:
var items = new DiagramItemCollection();
foreach (var item in diagram.Items)
	if (!(item is ContainerNode))
		items.Add(item);
var r = new OrthogonalRouter();
r.Arrange(diagram, items);
mihai
Reply #2 - Jul 28th, 2014 at 11:13am
Hi Stoyan,
Thanks, that did the trick!
The problem now is that I can't get the links to retain their anchor points. I have tried to:
  • Set the OrthogonalRouter.Anchoring to various values, including Anchoring.Keep
  • Set the Diagram.SnapToAnchor to OnCreateOrModify
but none produced the desired results.
All the links are between custom ShapeNode(s) with custom AnchorPattern(s), contained in ContainerNode(s), and they have the OriginAnchor & DestinationAnchor properties set.
Any ideas?
Best Regards,
-Mihai
« Last Edit: Jul 28th, 2014 at 2:49pm by mihai »
Reply #3 - Jul 28th, 2014 at 3:05pm
Hi Mihai,
This version should fix the Keep option:
https://mindfusion.eu/_beta/wpfdiag32.zip
mihai
Reply #4 - Jul 28th, 2014 at 3:09pm
Hi Stoyan,
Perfect, it works, thanks!
Will this fix make it into the next release?
Thanks again,
-Mihai
Reply #5 - Jul 28th, 2014 at 4:08pm
Yes, it should be available next month.
mihai
Reply #6 - Jul 28th, 2014 at 5:26pm
Cool, thanks again Stoyan.
