Hot Topic (More than 10 Replies) Link not moving with the node, when the moving is done programatically (Read 10163 times)
mihai
Aug 11th, 2014 at 1:07pm
I have two ShapeNodes connected through a link. One of the nodes (A) has anchor points defined, the other (B) doesn't. When I programatically relocate A, the link remains behind / is not moved. When I manually move any of these nodes though, using the mouse, the links snap back in place.
The link is created like this:
var link = diagram.Factory.CreateDiagramLink(nodeWithoutCustomAnchorPoints, nodeWithCustomAnchorPoints);
link.DestinationAnchor = someIndex;
link.Dynamic = false;
Can you please advise?
-Mihai
mihai
Re: Link not moving with the node, when the moving is done programatically
Reply #1 - Aug 12th, 2014 at 12:57pm
Stoyan, thoughts?
Reply #2 - Aug 12th, 2014 at 3:35pm
This updates the link correctly from click event for any of the nodes:
var a = diagram.Factory.CreateShapeNode(10, 10, 50, 50);
var b = diagram.Factory.CreateShapeNode(110, 10, 50, 50);
b.AnchorPattern = AnchorPattern.Decision2In2Out;
var link = diagram.Factory.CreateDiagramLink(a, b);
link.DestinationAnchor = 1;
private void OnNodeClicked(object sender, NodeEventArgs e)
	var r = e.Node.Bounds;
	r.Y += 10;
	e.Node.Bounds = r;
If you are calling node.SetBounds method instead of setting the Bounds property, make sure the second bool argument (updateLinks) is set to true.
mihai
Reply #3 - Aug 22nd, 2014 at 8:11am
Hi Stoyan,
I'm actually setting the Bounds property, but still having the issue.
I have investigated further, and the problem is really due to the container of these nodes being *programatically* relocated (I have several containers arranged with LayeredLayout).
What can I do to fix this?
-Mihai
Reply #4 - Aug 22nd, 2014 at 9:02am
Do you mean A and B nodes are in same container, and setting A.Bounds does not update the link when layout.Arrange() was applied previously?
mihai
Reply #5 - Aug 22nd, 2014 at 9:34am
Hi Stoyan,
Yes, it would appear that way.
However, I have indirectly fixed the problem by applying the link arrange algorithm *after* arranging the containers, so I think we can close this ticket for now.
-Mihai
mihai
Reply #6 - Sep 12th, 2014 at 12:26pm
Hi Stoyan,
Actually the problem reoccurred, so can you please look into it? To reproduce it:
  • Create a container node
  • Create a shape node with some anchor points, and add it into the container
  • Create a shape node without anchor points, and add it into the container
  • Create a link between the two shape nodes, with one side anchored to one of the defined anchor points
  • Move the container node programatically, like this: var newBounds = container.Bounds; newBounds.Offset(10, 0); container.Bounds = newBounds;
  • Notice how the link control points are left behind
-Mihai
« Last Edit: Sep 12th, 2014 at 7:25pm by mihai »
mihai
Reply #7 - Sep 15th, 2014 at 9:10am
Hi Stoyan,
Were you able to reproduce it?
Best Regards,
-Mihai
Reply #8 - Sep 15th, 2014 at 10:15am
Hi Mihai,
We could not reproduce that. Try copying your settings and event handlers to this test project to find what exactly causes it:
https://mindfusion.eu/_samples/MoveCtrTest.zip
mihai
Reply #9 - Sep 16th, 2014 at 8:58am
Hi Stoyan,
To reproduce, please modify your method as follows:
void CreateTestContainer()
	var ctr = diagram.Factory.CreateContainerNode(20, 50, 200, 200);
	ctr.Caption = "right-click me";
	var n2 = diagram.Factory.CreateShapeNode(120, 150, 50, 50);
	n2.AnchorPattern = null;
	n2.AttachTo(ctr, GroupAnchorStyles.Top | GroupAnchorStyles.Left | GroupAnchorStyles.Bottom);
	ctr.Add(n2);
	var n1 = diagram.Factory.CreateShapeNode(40, 70, 50, 50);
	n1.AnchorPattern = AnchorPattern.Decision1In3Out;
	ctr.Add(n1);
	var l = diagram.Factory.CreateDiagramLink(n1, n2);
	l.ControlPoints.Insert(1, new Point(105, 210));
	l.UpdateFromPoints(false, true);
It basically has to do with:
* The order of the nodes creation, and
* The attaching of the first created node to the container (a fact that I did not mention initially, thinking it's not relevant).
You can then also modify the offset from 10 to 100, to make this more obvious.
Best Regards,
-Mihai
Reply #10 - Sep 17th, 2014 at 8:35am
This version should fix that:
https://mindfusion.eu/_beta/wpfdiag32.zip
mihai
Reply #11 - Sep 18th, 2014 at 8:31am
Thanks Stoyan, it works!
-Mihai
mihai
Reply #12 - Sep 22nd, 2014 at 12:37pm
Hi Stoyan,
Actually, there is still a problem:
* Use the sample project, with the latest CreateTestContainer() method from this thread, and the patch you have provided
* Right-click on the container, to move it
* Then right-click on a child node from the container, to move it
* Notice how the link remains behind.
-Mihai
Reply #13 - Sep 23rd, 2014 at 10:51am
Try new build from
mihai
Reply #14 - Sep 23rd, 2014 at 1:56pm
Thanks Stoyan, that did the trick!
-Mihai
