Normal Topic [VB.NET] ScrollBars Handle (Read 4579 times)
SGS Software
Sep 30th, 2014 at 7:56am
I'm going to develope an hotel booking planner, with full year
and al least 500 rooms.
I load the full year from MindFusion with the start and end date,
but for the rooms and the occupations I disabled
the vertical scroll replacing with a simple VScrollBar which show the paginated RecordSet from
(Room_x) to (Room_x ) + NumberOfVisibleRooms
and from
FirstVisibleDate to LastVisibleDate
so I am able to load just the needed range of time and data.
My question is: can I set a maximum value for the MindFusion scrollbars so I have the right styled component's scrollbar?
Otherwise, if not possible, can I set the "system style" for the MindFusion scrollbars?
Thank you!
Re: [VB.NET] ScrollBars Handle
Reply #1 - Sep 30th, 2014 at 8:10am
You cannot access the scrollbars directly, but you can toggle the style of all child controls (scrollbars and buttons) in the calendar through the ControlAppearance property:
calendar.ControlAppearance = ControlAppearance.System;
I hope this helps.
SGS Software
Reply #2 - Sep 30th, 2014 at 1:07pm
Meppy wrote on Sep 30th, 2014 at 8:10am:
I hope this helps.
Yes, it helps, al least to give uniformity to the aspect,
but it would be really nice - in a future release - be able to manage the scrollbar to set custom ranges/values!
I have another question, I open another topic so can be easily read by other users.
Thank you again.
