Normal Topic BpmnEndTerminate coloring (Read 1922 times)
Sim
Oct 8th, 2014 at 10:14am
I am trying to change the way my nodes are being displayed. I am running into an issue when trying to change the BpmnEndTerminate shape. I am able to change the background color as well as the border color but not the rest of the node.
My current code for changing the colors is:
Node.Brush = new MindFusion.Drawing.SolidBrush(Color.White);
Node.Pen = new MindFusion.Drawing.Pen(Color.Yellow);
I have attached an image of the result that I'm having right now and the result I would expect. How can I achieve my expected result?
Re: BpmnEndTerminate coloring
Reply #1 - Oct 8th, 2014 at 10:42am
Colors of shape's filled decorations can be set only through the Shape class, and you can specify that all BpmnEndTerminate nodes should be yellow like this:
var yellow = new SolidBrush(Color.Yellow);
var innerCircle = Shapes.BpmnEndTerminate.ShapeDecorations[0];
innerCircle.Brush = yellow;
innerCircle.Pen = new Pen(yellow);
var outerCircle = Shapes.BpmnEndTerminate.ShapeDecorations[1];
outerCircle.Brush = yellow;
outerCircle.Pen = new Pen(yellow);
At this time it's not possible to set these colors to different values for different nodes, unless you clone the shape for each node (or for each color if using only a few colors, e.g. create YellowBpmnEnd, RedBpmnEnd, etc. shapes). You can also implement that using custom drawing, setting the specific colors as above from DrawNode event handler, and calling the Shape.Draw method.
Sim
Reply #2 - Oct 8th, 2014 at 11:15am
This worked perfectly, thank you very much!
