Normal Topic Huge ToolTip freezes MindFusion (Read 2235 times)
j poz
Oct 20th, 2014 at 6:08pm
Open the demo project, and set a ShapeNode's ToolTip to be a really long string (like "aaaaaaaaaaaaaa[...]"). The demo project will freeze, demonstrating this bug..
j poz
Re: Huge ToolTip freezes MindFusion
Reply #1 - Oct 20th, 2014 at 9:09pm
It will freeze when you hover over the ShapeNode so the tooltip shows, I mean.
Reply #2 - Oct 21st, 2014 at 9:39am
Apparently the delay comes from .NET's ToolTip control text formatting code:
http://stackoverflow.com/questions/17877009/winfroms-tooltip-works-very-slow-for...
You could add your own line breaks to work around that:
var n = diagram.Factory.CreateShapeNode(10, 10, 20, 20);
var tt = new string('a', 4000);
int lastWhitespace = 0;
for (int i = 0; i < tt.Length; i++)
	if (char.IsWhiteSpace(tt[i]))
		lastWhitespace = 0;
	else
		lastWhitespace++;
	if (lastWhitespace > 200)
		tt = tt.Insert(i, Environment.NewLine);
		lastWhitespace = 0;
n.ToolTip = tt;
