Normal Topic TableNode 3 columns vertical text (Read 1622 times)
ZoomTool Company
Nov 2nd, 2014 at 1:14pm
Hi
I would like to have table node that has 3 columns - the first two columns group the rows in third column. I.e. More like group reporting. First two columns should span multiple rows. And to save space first two columns text content is virtical while the 3 column rows are horizontal.
In short, if a column's text value repeats multiple rows then we should be able to group the columns into one cell spanning multiple rows and display it as vertical running text.
Is there a way to do this? That you in advance.
Re: TableNode 3 columns vertical text
Reply #1 - Nov 3rd, 2014 at 8:43am
There is no built-in support for grouping. You can specify how many rows should be spanned by a cell by setting its RowSpan property, so you could implement that yourself using this method:
void MergeCells(TableNode table, int column)
	int startIndex = 0;
	while (startIndex < table.Rows.Count)
		int span = 1;
		while (startIndex + span  < table.Rows.Count &&
			table[column, startIndex].Text == table[column, startIndex + span].Text)
			span++;
		if (span > 1)
			table[column, startIndex].RowSpan = span;
			table[column, startIndex].TextFormat.FormatFlags =
				StringFormatFlags.DirectionVertical;
		startIndex += span;
var t = diagram.Factory.CreateTableNode(10, 10, 30, 100, 3, 20);
t[0, 0].Text = "test 1";
t[0, 1].Text = "test 2";
t[0, 2].Text = "test 2";
t[0, 3].Text = "test 2";
t[0, 4].Text = "test 3";
t[0, 5].Text = "test 4";
t[0, 6].Text = "test 4";
t[0, 7].Text = "test 5";
MergeCells(t, 0);
