Normal Topic Background for single RowHeader (Read 4125 times)
hdbnoehfbo
Nov 28th, 2014 at 3:50pm
I need to change the Header Background for specific rows, similar to
calendar.ResourceViewSettings.HeaderStyle.Background = Brushes.White;
but only for some rows. I generate the headers dynamically during startup before the calendar is displayed, so I need a method to change the backgroundcolor after I generated the data. How is it possible to do this?
Re: Background for single RowHeader
Reply #1 - Dec 1st, 2014 at 7:46am
You can do that by using a custom RowHeaderTemplate. First, you can associate a brush with each resource through its Tag property. Alternatively you can define a custom resource class, which exposes a new property for the background brush.
calendar.ItemResources.Add(new Resource() { Name = "resource 1", Tag = Brushes.Red });
calendar.ItemResources.Add(new Resource() { Name = "resource 2", Tag = Brushes.Green });
calendar.ItemResources.Add(new Resource() { Name = "resource 3", Tag = Brushes.Orange });
calendar.ItemResources.Add(new Resource() { Name = "resource 4", Tag = Brushes.Purple });
Then you can specify a custom RowHeaderTemplate, which binds to the background property:
<p:Calendar x:Name="calendar" CurrentView="ResourceView">
	<p:Calendar.ResourceViewSettings>
		<p:ResourceViewSettings>
			<p:ResourceViewSettings.RowHeaderTemplate>
				<DataTemplate>
					<Border Background="{Binding Resource.Tag}">
						<TextBlock Text="{Binding HeaderText}" HorizontalAlignment="Center" VerticalAlignment="Center" />
					</Border>
				</DataTemplate>
			</p:ResourceViewSettings.RowHeaderTemplate>
		</p:ResourceViewSettings>
	</p:Calendar.ResourceViewSettings>
</p:Calendar>
Finally, you need to set the appropriate alignment for the header content (by default it appears centered inside the header):
calendar.ResourceViewSettings.HeaderStyle.HorizontalAlignment = HorizontalAlignment.Stretch;
calendar.ResourceViewSettings.HeaderStyle.VerticalAlignment = VerticalAlignment.Stretch;
I hope this helps.
hdbnoehfbo
Reply #2 - Dec 3rd, 2014 at 12:18pm
Thanks, this is exactly what I was looking for.
