Normal Topic Move selection by code (Read 1878 times)
Hunter
Dec 4th, 2014 at 8:25am
Hello.
How can I move selection by code? In moment when user tries to move the node (Selection.Items.Count == 1) I need to add some nodes into the Selection and move all selected nodes. Now I catch the event NodeStartModifying and add necessary node by Selection.AddItem method. By only first active node moves after that.
Re: Move selection by code
Reply #1 - Dec 4th, 2014 at 9:09am
If you need dependent nodes to always follow movements of some node, you could attach them to the main node using AttachTo method. If you need to select and move only in specific circumstances, try using a Behavior class:
diagram.CustomBehavior = new SelectionBehaviorEx(diagram);
class SelectionBehaviorEx : LinkShapesBehavior
	protected internal SelectionBehaviorEx(Diagram diagram) :
		base(diagram)
	public override InteractionState StartDraw(Point point)
		var interaction = base.StartDraw(point);
		if (interaction.Action == Action.Modify &&
			interaction.AdjustmentHandle == 8 /* move */ &&
			interaction.CurrentItem is DiagramNode)
			// select extra nodes
			Diagram.Nodes[1].Selected = true;
			return new InteractionState(Diagram.Selection,
				interaction.AdjustmentHandle, interaction.Action);
		return interaction;
Hunter
Reply #2 - Dec 4th, 2014 at 12:16pm
Yes, it works. Thank you
