Normal Topic how to make a groupNode which can contain nodes with links ? (Read 1932 times)
heyx
Apr 2nd, 2015 at 2:26am
hi,
   I use AttachTo method crate a GroupNode. but if the node has linked with other node. I don't know how to attach the link  to GroupNode.
  Could you please give me some help?
Re: how to make a groupNode which can contain nodes with links ?
Reply #1 - Apr 2nd, 2015 at 9:23am
Links cannot be attached to a group. If they connect two nodes attached to same corner of master, they should still follow the master node when moved (with all control points translated by master's offset).
void CreateTestGroup()
	var main = diagram.Factory.CreateShapeNode(50, 50, 200, 200);
	var child1 = diagram.Factory.CreateShapeNode(70, 70, 30, 30);
	child1.AttachTo(main, AttachToNode.TopLeft);
	var child2 = diagram.Factory.CreateShapeNode(180, 150, 30, 30);
	child2.AttachTo(main, AttachToNode.TopLeft);
	diagram.Factory.CreateDiagramLink(child1, child2).SegmentCount = 4;
