Hot Topic (More than 10 Replies) Create a Flowchart Diagram dynamically by reading the values/dependency from Oracle Database (Read 20173 times)
Re: Create a Flowchart Diagram dynamically by reading the values/dependency from Oracle Database
Reply #15 - Jun 10th, 2015 at 7:42pm
I've installed Oracle DB Express and played with following tables:
JOBS { ID, NAME }
DEPENDENCIES { ID, PARENT_JID, DEP_JID }
This code seems to select graph subset correctly, though I'm not sure if it's the most efficient way to implement that:
var connection = new OracleConnection(
	@"User Id=mindfusion;Password=password_min;Data Source=//localhost:1521/xe");
connection.Open();
var rect = new RectangleF(0, 0, 30, 20);
int parentID = 1;
int depth = 4;
// create node for the root job
OracleCommand parentCommand = connection.CreateCommand();
parentCommand.CommandText = string.Format(
	"select * from JOBS where ID={0}", parentID);
OracleDataReader parentReader = parentCommand.ExecuteReader();
while (parentReader.Read())
	var node = diagram.Factory.CreateShapeNode(rect);
	node.Id = parentReader.GetInt32(0);
	node.Text = parentReader.GetString(1);
// create nodes for dependencies found up to given depth in hierarchy
OracleCommand jobsCommand = connection.CreateCommand();
jobsCommand.CommandText = string.Format(
	"select JOBS.ID, JOBS.NAME, DEPENDENCIES.PARENT_JID, DEPENDENCIES.DEP_JID, LEVEL " +
	"from JOBS inner join DEPENDENCIES on JOBS.ID=DEPENDENCIES.DEP_JID " +
	"where LEVEL<{0} " +
	"start with DEPENDENCIES.PARENT_JID={1} " +
	"connect by prior DEPENDENCIES.DEP_JID=DEPENDENCIES.PARENT_JID",
	depth, parentID);
OracleDataReader jobsReader = jobsCommand.ExecuteReader();
while (jobsReader.Read())
	int parentId = jobsReader.GetInt32(2);
	int childId = jobsReader.GetInt32(3);
	var parent = diagram.FindNodeById(parentId);
	var child = diagram.FindNodeById(childId);
	if (child == null)
		child = new ShapeNode(diagram)
			Id = childId,
			Text = jobsReader.GetString(1),
			Bounds = rect
		diagram.Nodes.Add(child);
	diagram.Factory.CreateDiagramLink(parent, child);
var layout = new LayeredLayout();
layout.Arrange(diagram);
connection.Close();
SE
Reply #16 - Jun 15th, 2015 at 2:31pm
Good Morning!
Now I have a query that results with hierarchical subsets for a particular job. and I am able to form the graph depends on that.
But the nodes which are not present by the result set also shown in the flowchart as lonely nodes. please refer the attached image. Job B, A and C1 should not be in the graph as per the result set even though it exists in the dependency table.
Can you please help.
« Last Edit: Jun 15th, 2015 at 3:43pm by SE »
Reply #17 - Jun 15th, 2015 at 2:46pm
Do you still keep the loop from first code example that creates nodes from "select * from Jobs" results? You should remove that now, as the Dependencies loop from last example creates nodes when necessary (the diagram.Nodes.Add part)
SE
Reply #18 - Jun 15th, 2015 at 3:38pm
Hi, I dont think i got your point. How will the JobId be fetched if i remove this parent table query?
So, this is my parent table query
command.CommandText = "select JOB_ID,JOB_NAME from Jobs";
command.Connection = connection;
OracleDataReader reader = command.ExecuteReader();
int index_jobId = reader.GetOrdinal("JOB_ID");
« Last Edit: Jul 14th, 2015 at 7:40pm by SE »
Reply #19 - Jun 15th, 2015 at 4:21pm
You will get the job's ID and Name from the JOIN operation if using same query as in my example:
	depth, parentID);
Since you wanted to get results only for hierarchical subset from your huge data and the dependencies are stored in a separate table, you will have to use JOIN to query it. If you don't mind fetching all data, you might as well use the older example and just delete nodes that are at longer distance from the root than you want to show.
Reply #20 - Oct 16th, 2015 at 8:42am
If you aren't seeing any nodes in the diagram, Factory.CreateShapeNode has probably never been called, and so later FindNodeById will return null. Try tracing through node-creation part of your code to see why.
