Normal Topic preview of diagram library for iOS (Read 13775 times)
Jun 26th, 2015 at 11:43am
We have implemented most of the core MindFusion diagramming API as a Swift 2.0 module. If anyone is interested in trying out a preview build, please download this archive containing the framework file and a simple application project:
https://mindfusion.eu/_beta/SwiftDiagram.zip
The DiagramView control is fully interactive and lets you draw and connect ShapeNode, TableNode, TreeViewNode and ContainerNode objects, based on the value of its Behavior property. The library also includes a NodeListView control that enables drag-and-drop creation of nodes. Features planned for v1.0 release that are not yet implemented are styled text and automatic layout algorithms.
In order to integrate Diagramming.framework into a new Xcode project, add it to Embedded Binaries and Linked Frameworks sections under target's General tab:
and Link Binary with Libraries and Embed Frameworks sections on Build Phases tab:
In addition, on Build Settings tab enable the Embedded Content Contains Swift Code property and add the Diagramming.Framework path to Framework Search Paths list, possibly using $(SRCROOT) value to find copy in local project folder:
In order to add a diagram view to a storyboard screen, create a View object, set its class in identity inspector to DiagramView, and set the type of its controller class to DiagramViewController.
« Last Edit: Jun 30th, 2015 at 7:00am by Stoyo »
Re: preview of diagram library for iOS
Reply #1 - Jul 30th, 2015 at 2:11pm
This new build implements the LayeredLayout algorithm for automatic graph layout:
It can be applied by calling the Diagram.arrange method with a LayeredLayout instance as argument:
let defBounds = Rect(x: 0, y: 0, width: 20, height: 20)
let factory = dview.diagram.factory
let n1 = factory.createShapeNode(defBounds); n1.text = "1"
let n2 = factory.createShapeNode(defBounds); n2.text = "2"
let n3 = factory.createShapeNode(defBounds); n3.text = "3"
let n4 = factory.createShapeNode(defBounds); n4.text = "4"
let n5 = factory.createShapeNode(defBounds); n5.text = "5"
let n6 = factory.createShapeNode(defBounds); n6.text = "6"
factory.createDiagramLink(n1, destination: n2)
factory.createDiagramLink(n1, destination: n3)
factory.createDiagramLink(n2, destination: n4)
factory.createDiagramLink(n2, destination: n5)
factory.createDiagramLink(n4, destination: n6)
factory.createDiagramLink(n5, destination: n6)
factory.createDiagramLink(n3, destination: n6)
factory.createDiagramLink(n1, destination: n6)
let layout = LayeredLayout()
dview.diagram.arrange(layout)
Reply #2 - Sep 7th, 2015 at 1:50pm
This new build implements SpringLayout, FractalLayout and TreeLayout algorithms for automatic graph layout:
func onSpringLayout(sender:UIButton!)
    let layout = SpringLayout()
    diagramView.diagram.arrange(layout)
Reply #3 - Oct 26th, 2015 at 10:52am
A new build of the iOS diagram component is now available:
1. The framework has been compiled using final released version of Swift 2.0 compiler.
2. The archive includes initial help reference in HTML format.
3. A built-in context menu allows deleting diagram items and starting in-place edit operations. The menu shows after a long press, and also raises contextMenuCreated event that lets you add custom commands to the menu or remove built-in ones.
Online
Reply #4 - Dec 6th, 2016 at 7:11pm
We have rebuilt the framework bundle using Swift 3 compiler  -
ETA for official release is end of December.
Online
Reply #5 - Jan 4th, 2017 at 12:23pm
We have released v1.0 of the iOS diagram library. Distribution is now available here -
https://mindfusion.eu/SwiftDiagram.zip
ato276
Reply #6 - Jul 10th, 2017 at 8:43pm
Can you update the preview of diagram library for iOS to newest Swift Version?
I have problem with Xcode 8.3.3 when try to compile the library: "Module compiled with Swift 3.0.2 cannot be imported in Swift 3.1"
Thanks!
Online
Reply #7 - Jul 11th, 2017 at 7:46am
We'll try to update it today.
Online
Reply #8 - Jul 11th, 2017 at 2:12pm
This build has been compiled using Swift 3.1 -
