Hot Topic (More than 10 Replies) Attach to link (Read 17182 times)
Re: Attach to link
Reply #15 - Oct 7th, 2015 at 4:19pm
Call nodes' getCenter() methods, find horizontal and vertical offsets and compare them:
float dx = nodeCenter.x - decisionCenter.x;
float dy = nodeCenter.y - decisionCenter.y;
if (dx > dy)
  if (dx > 0) { /* decision on left of node */ }
  if (dx < 0) { /* decision on right of node */ }
else
  if (dy > 0) { /* decision above node */ }
  if (dy < 0) { /* decision below node */ }
Silvia88
Re: Attach to link
Reply #16 - Oct 7th, 2015 at 4:55pm
Ok, thank you very much, but then in the first two cases I use Orientation.vertical while in the other two orientation.horizontal, right?
Re: Attach to link
Reply #17 - Oct 7th, 2015 at 6:43pm
This corresponds to the orientation of first segment, I cannot tell it from the picture.
Silvia88
Re: Attach to link
Reply #18 - Oct 24th, 2015 at 4:23pm
Hi, is it possible to determine which is the link to which a node is attached? I mean I have a node which is attached to a link and I want to get that link
Re: Attach to link
Reply #19 - Oct 26th, 2015 at 6:17am
You can find it from the Group object created for attachments:
DiagramLink masterLink = null;
if (node.getMasterGroup() != null &&
	node.getMasterGroup().getMainItem() instanceof DiagramLink)
	masterLink = (DiagramLink)node.getMasterGroup().getMainItem();
