Normal Topic CellClicked event and NodeClicked event (Read 1884 times)
CanadaProgrammer
Sep 16th, 2015 at 3:34am
when i click a cell, both CellClicked event and NodeClicked event are fired. Is there any way to stop NodeClicked event when I click a cell?
Thanks a lot
Re: CellClicked event and NodeClicked event
Reply #1 - Sep 16th, 2015 at 9:21am
You could ignore NodeClicked if args.Node is TableNode, or if there aren't cells at mouse pointer location, depending on what you are trying to achieve (e.g. process clicks only for other kinds of nodes, or still process clicks over table caption):
void OnNodeClicked(object sender, NodeEventArgs e)
    var table = args.Node as TableNode;
    //if (table != null) return;
    if (table != null && table.CellFromPoint(args.MousePosition, ref row, ref col))
        return;
