Normal Topic MindFusion.Licensing.LicenseManager.AddLicense question (Read 6052 times)
SE
Sep 23rd, 2015 at 1:49pm
We purchsed a license for .NET mindfusion package.
Now i need to know where/how to call this property to add the license key? MindFusion.Licensing.LicenseManager.AddLicense .
I am adding it here.
private void IntializeComponenet()
this.diagramView1.LicenseKey = "Key code"
Is this correct? if yes, how can i test to make sure it is not in trial version mode anymore?
also, if i want to use this one, where should i call this method? Please advise the best option.
MindFusion.Licensing.LicenseManager.AddLicense?
Re: MindFusion.Licensing.LicenseManager.AddLicense question
Reply #1 - Sep 23rd, 2015 at 2:03pm
You can either set the LicenseKey property or call AddLicense method, it doesn't matter. AddLicense is more convenient if you have more than one DiagramView in different windows, as you won't have to set the property for each one.
If you haven't set the key, the component starts displaying trial message when there are more than 20 nodes in the diagram, so you could create 21 nodes from a loop and verify it's not showing.
SE
Reply #2 - Sep 23rd, 2015 at 2:09pm
Thank you.I will test.
Where should i call this property in the code if i want to use this one?
MindFusion.Licensing.LicenseManager.AddLicense("key code")
Reply #3 - Sep 23rd, 2015 at 2:13pm
Any start-up code invoked before the diagram shows will do, for example application or form classes' constructors, form.Load handler, application's Main method.
SE
Reply #4 - Sep 23rd, 2015 at 2:15pm
ok, Will check. One more question-
will it hurt if i have both license key property set and also the MindFusion.Licensing.LicenseManager.AddLicense in the code?
Reply #5 - Sep 23rd, 2015 at 2:26pm
It won't hurt, it will just return without doing any heavy processing if you set same code for a second time.
SE
Reply #6 - Sep 23rd, 2015 at 2:30pm
Thannk you! This information is very helpful.
