Normal Topic NodeStartModifying and NodeModified events (Read 3441 times)
David Long
Sep 30th, 2015 at 1:19pm
Sometimes if a node is only moved a small distance (a millimeter or two) I get a NodeStartModifing event but no NodeModified event. This is annoying as I start a composite command and hide a link arrow in the NodeStartModifing event handler in preparation for a custom drag and drop operation. Is there any way I can force the NodeModified event to occur?
David L
Re: NodeStartModifying and NodeModified events
Reply #1 - Sep 30th, 2015 at 3:51pm
The operation is cancelled if mouse pointer was moved only a few pixels, in order to avoid incidental modifications if the user only wanted to click. You could detect that from NodeModifyCancelled event handler. You could force it to accept smaller movements by setting diagram.Interaction.MouseMoved to true from NodeStartModifing handler.
David Long
Reply #2 - Sep 30th, 2015 at 5:44pm
Thanks, the "diagram.Interaction.MouseMoved to true" solution worked well.
DavidL
