Normal Topic ActionUndo (Read 5825 times)
Silvia88
ActionUndo
Sep 30th, 2015 at 7:23pm
how can I get the node or link that has been modified or added by the undo command?
Re: ActionUndo
Reply #1 - Oct 1st, 2015 at 10:35am
Handle the DiagramListener.actionUndone event and inspect UndoEvent.getCommand().getItem(), after type-casting the command to appropriate type, e.g. AddItemCmd or ModifyItemCmd.
Silvia88
Re: ActionUndo
Reply #2 - Oct 1st, 2015 at 12:14pm
ok, thank you very much, I'll try Smiley Is there also a way to avoid to do undo to resize the node? I mean I have a node, I put some text on it, then I resize the node according to the text with the method resizeToFitText(FitSize.KeepRatio), when I click undo firstly it deletes the text then resizes the node till when it reaches the starting dimensions and then it deletes the node, but I want to avoid these passages of resize I want to delete the text and with the next undo delete the node.
Re: ActionUndo
Reply #3 - Oct 1st, 2015 at 3:04pm
Try using CompositeCmd command to enclose the ChangeItemCmd objects you create for other operations:
CompositeCmd composite = diagram.getUndoManager().startComposite("change text");
// run other commands here
composite.execute();
Alternatively, call CommandHistory.mergeUndoRecords method to merge last few commands in history into a single composite command.
Silvia88
Re: ActionUndo
Reply #4 - Oct 1st, 2015 at 3:25pm
Ok, thank you very much  Smiley
Silvia88
Re: ActionUndo
Reply #5 - Oct 5th, 2015 at 8:26am
Sorry I tried but it doesn't work, how can I do? Can I have an example of how command history works? Should I do it in the listener of the undo or in actionUndone?
Re: ActionUndo
Reply #6 - Oct 5th, 2015 at 1:03pm
actionUndone handler is too late as it means the user has already undone one of the actions you'd want to be merged with others. Try this if setting text from code:
CompositeCmd composite = undoMan.startComposite("set text");
// property changes aren't saved automatically, use ChangeItemCmd
ChangeItemCmd changeText = new ChangeItemCmd(testNode, "set text");
testNode.setText("test");
diagram.executeCommand(changeText);
testNode.resizeToFitText(FitSize.KeepRatio);
