Normal Topic Charting for WinForms, V4.0 (Read 3956 times)
Apr 6th, 2016 at 3:27pm
Version 4 of MindFusion.Charting for Windows Forms includes a new design of the library API with following new features:
New data model
Data that should be drawn in charts is read through an interface called Series, whose instances can be assigned to the Series properties of Chart and SeriesRenderer classes. You could implement this interface in your own model classes to avoid duplicating data. Alternatively, if a model class is sealed but provides API to access its data, you could implement the interface in an adapter class. The library includes several pre-defined series classes that let you specify data via IList or array objects. For example, BarSeries lets you specify lists of values, inner labels and top labels, and PointSeries lets you specify data as a list of points. In addition, the DataBoundSeries and XmlSeries implementations can be used to automatically read from a .NET data source or from an XML document. Instances of latter series types are automatically generated when chart's DataSource property is set.
New rendering model
Chart graphics are drawn inside Plot components by SeriesRenderer -derived objects. Each plot can contain multiple series renderers from same or different types. For example, you can draw area, line and bar graphics in same plot by adding AreaRenderer, LineRenderer and BarRenderer objects to its SeriesRenderers collection. Concrete Chart classes automatically generate a series renderer of appropriate type for their Series.
Dashboard
The Dashboard control can contain multiple plots, axes, legends, images, gauges and text blocks arranged in dynamic layout. Individual components can be added to dashboard's default RootPanel or LayoutPanel containers, or for more complex layouts add intermediary panels such as GridPanel and StackPanel to the default ones. To show different types of chart graphics, add Plot2D to draw in 2D Cartesian coordinate system, Plot3D for 3D Cartesian system, and PolarPlot for polar coordinate system. To draw horizontal or vertical axes, add respectively XAxisRenderer and YAxisRenderer objects. To show gauges, add LinearGaugeRenderer or OvalGaugeRenderer, whose Gauge property contains the gauge model definition.
Print and export
The Dashboard control and Chart controls that derive from it expose Print and PrintPreview methods for printing on paper. Call the ExportImage and CreateImage methods to generate bitmap image of the dashboard. The ExportPdf method exports the chart to a PDF (Portable Document Format) file. The ExportSvg method exports the chart to an SVG (Scalable Vector Graphics) file.
Styling
Values of appearance properties can come from several places in the component hierarchy. SeriesRenderer -derived objects can use attributes from their local SeriesStyle, from plot's SeriesStyle, or from the *Series properties in current Theme. Component classes use either their local properties or ones defined in the theme. By default, appearance properties in SeriesRenderer and Component classes have null values, which makes the drawing code use values from the theme.
https://www.mindfusion.eu/ChartWinForms.zip
Updated assemblies are also available as MindFusion.Charting NuGet package.
« Last Edit: Jan 9th, 2022 at 1:05pm by Forum Admin »
Charting for WinForms, V4.0.1
Reply #1 - May 3rd, 2016 at 1:01pm
Version 4.0.1 of MindFusion.Charting for WinForms contains the following fixes and new features:
  • TickLength property added to AxisRenderer. XAxisTickLength and YAxisTickLength properties added to BiaxialChart.
  • LabelAlignment property added to BubbleRenderer and BubbleChart.
  • ShowTitle property added to LegendRenderer, and corresponding ShowLegendTitle property added to Chart.
  • Spacing property added to LegendRenderer, and corresponding LegendSpacing property added to Chart.
  • GridLineColor, GridLineStyle and GridLineThickness properties added to Plot2D and Theme classes.
  • Fixed crash in pie charts for zero values.
  • Bubbles in bubble charts are now properly centered on their values.
  • Fixed YAxisLabel alignment in horizontal bar charts.
https://www.mindfusion.eu/ChartWinFormsTrial.zip
