Normal Topic Updating from FPS.VirtualKeyboard (Read 4502 times)
Chris M
May 2nd, 2016 at 3:47pm
Do you have any information on what needs to be done to update from a previous FPS Components Virtual Keyboard solution to Mindfusion?
Re: Updating from FPS.VirtualKeyboard
Reply #1 - May 2nd, 2016 at 4:09pm
You can find API changes listed here -
http://www.mindfusion.eu/onlinehelp/keyboard.winforms/index.htm?What_s_New_in_th...
The new build will no longer work with FPS serial numbers. If you have a license for our Windows Forms pack, assign your key to Keyboard.LicenseKey property, otherwise you can request a keyboard-only key at our support email address.
Chris M
Reply #2 - May 2nd, 2016 at 4:26pm
I changed the project reference, namespace references, and property and eventargs.  I also modified our
FPS.VirtualKeyboard.Common.LicenseValidator.LicenceKey = "....."
to be
MindFusion.Licensing.LicenseManager.AddLicense(".....")
The solution now builds and seems to run correctly after these changes.
But are you saying the license key we have been using that we obtained through FPS is no longer valid and we should obtain a new one from Mindfusion?
Chris M
Reply #3 - May 2nd, 2016 at 4:30pm
Also, we have several custom keyboard XML files.  Since the "Repetition" property has now been changed to "Repeat", do we need to recreate all of our XML custom keyboard files?
Reply #4 - May 2nd, 2016 at 5:24pm
Quote:
The solution now builds and seems to run correctly after these changes. But are you saying the license key we have been using that we obtained through FPS is no longer valid and we should obtain a new one from Mindfusion?
It should be displaying a trial watermark if you don't assign a key in our format, doesn't it? If you want to move to Mindfusion version of the keyboard assembly you will need a new key, which you will get for free if you had active maintenance with FPS. (Your old key will still work with the original FPS build)
You could use the "Replace All in Files" command of Visual Studio to replace Repetition with Repeat in the XML layout files.
