Normal Topic Hindi keyboard displays wrong key appearance for 6 keys (Read 9201 times)
Mike Farough
Jul 12th, 2017 at 10:57pm
If I run the Virtual Keyboard Layout Creator for Language "Hindi (India) and open a new default keyboard, the displayed key for 4,5,6,7, and 8 are all wrong for their alternate "shift" value.
All of these keys display a circle with a slash below them, matching the standard value for the "D" equivalent key.
However, if I press shift and then any of the 4-8 keys, the output does not match.
Their Hindi keyboard displays the output value for these shift keys correctly on the keyboard. Is there any way to get the correct display in FPS?
Mike Farough
Re: Hindi keyboard displays wrong key appearance for 6 keys
Reply #1 - Jul 12th, 2017 at 10:58pm
Note that if I visit this URL:
http://gate2home.com/Hindi-Keyboard
Their virtual keyboard displays the output value correctly on these keys. So I think this is an issue specific to FPS keyboard?
Reply #2 - Jul 13th, 2017 at 6:19am
The keyboard does not store key labels for languages but asks the Win32 API what's the character for a given key code and locale. We'll try to add fixed labels for these specific keys in next few days.
Mike Farough
Reply #3 - Jul 13th, 2017 at 7:55pm
And then you will release a patch at that point?
Reply #4 - Jul 13th, 2017 at 8:00pm
Yes.
Reply #5 - Jul 15th, 2017 at 5:02pm
This build should show correct labels -
https://mindfusion.eu/_temp/kb_hindi.zip
Mike Farough
Reply #6 - Jul 17th, 2017 at 4:27pm
I'm using an older version of the keyboard DLL that required me to add this line before InitializeComponent():
MindFusion.Licensing.LicenseManager.AddLicense(...)
This method no longer exists in the patch you have put out for me - will this cause me issues when I deploy to customers? Should I be adding my runtime license key in a different method now? Thanks!
Reply #7 - Jul 17th, 2017 at 4:37pm
The method still exists, check if you haven't missed adding reference to the new mindfusion.licensing assembly from zip file.
Mike Farough
Reply #8 - Jul 17th, 2017 at 5:34pm
Okay thanks, everything is working well now!
