Normal Topic InteractionState constructor changed from 6.0.3 to 6.3 (Read 2247 times)
Kyle Chen
Jul 26th, 2016 at 7:14pm
Hi Stoyo,
Recently I'm working on upgrade my MindFusion from 6.0.3 to 6.3. I noticed there's a change in constructor of InterationState class. The first parameter was "selection" but now it's the Node. However I customized the ModifyBehavior to do selection duplication with Ctrl+Move.
If in 6.3 I pass the current ActivateItem, it will only move the active node. However I want all selection to be moved together.
Code (C++)
public override InteractionState StartDraw(PointF point)
    if ((Control.ModifierKeys & Keys.Control) != 0)
        // duplicate
        if (_messageView.DuplicateSelection(true, _sourceElements, _duplicatedElements))
            Selection selection = DiagramView.Diagram.Selection;
            if (selection != null && selection.Items.Count > 0)
				AdjustmentHandle handle = new NodeAdjustmentHandle(NodeHandleType.Move);
				return new InteractionState([color=#ff0000]DiagramView.Diagram.ActiveItem[/color], handle, MindFusion.Diagramming.Action.Modify);
    return base.StartDraw(point);
Is there any way to keep this? Thank you!
Re: InteractionState constructor changed from 6.0.3 to 6.3
Reply #1 - Jul 26th, 2016 at 7:26pm
Hi there,
The first parameter has always been of type DiagramItem, which the Selection class derives from as well. So passing diagram.Selection to InteractionState constructor should still work. What changed is the second argument - from integer index to AdjustmentHandle reference. You should be able to pass NodeAdjustmentHandle.Move to it when you want to move multiple selection.
Kyle Chen
Reply #2 - Jul 26th, 2016 at 8:00pm
Correct! Sorry I didn't check it carefully. Thank you! Grin
Slavcho wrote on Jul 26th, 2016 at 7:26pm:
Hi there,
