Normal Topic Adding custom tempates to the shape designer (Read 1654 times)
Cyrinael
Aug 3rd, 2016 at 8:27am
I have found a post from more than one year ago where the possibility to add templates to the shape designer was asked. (http://mindfusion.eu/Forum/YaBB.pl?num=1423663963)
Is there now a possibility to add custom elements to the template section?
Thank you,
Cyrinael
Re: Adding custom tempates to the shape designer
Reply #1 - Aug 3rd, 2016 at 9:55am
I can only see internal classes used to fill the right-hand side palette. I guess since the customer has not confirmed if suggested additions would help them, our developers haven't invested time in that. If you simply need to show all pre-defined shapes to let users import them into designer, you can use the NodeListView as suggested in the topic you've linked above, or the new ShapeListBox control we've added recently (http://mindfusion.eu/Forum/YaBB.pl?num=1467189473).
Cyrinael
Reply #2 - Aug 3rd, 2016 at 11:02am
Hi Slavcho,
I'm thinking of making my own Shape Designer with a normal Diagram component. I will use ShapeControlPoints to enable the dragging like in the shape designer. Furthermore, I will make my own Template Sidebar
Thank you,
Cyrinael
