Normal Topic Assigning a ShapeNode from a DiagramNodeList to another deletes it from the origin list. (Read 1527 times)
Cyrinael
Aug 22nd, 2016 at 7:36am
I want to store a DiagramNodeList of ShapeNodes seperately to the Nodes in the Diagram. Both lists should contain the same nodes (reference equal). Sadly I cannot have the same ShapeNode in both lists, because if I assign the ShapeNode to the list, it is deleted in the Diagram and vice versa.
I also tried it with a List<ShapeNode> but the result was the same.
 foreach (DiagramNode node in diagramNodeList)
                    node.Id = shapeEntry.Key;
                    saveDiagram.Nodes.Add(node); //here the node gets removed from diagramNodeList
As a result of the code above, an exception is thrown, because the origin list is modified.
I also think that in a previous build, this problem did not occur but I am not totally sure about that.
Best regards,
Cyrinael
Cyrinael
Re: Assigning a ShapeNode from a DiagramNodeList to another deletes it from the origin list.
Reply #1 - Aug 22nd, 2016 at 8:19am
I have found the problem.
The ShapeNodes in the list were displayed in another diagram and were deleted after the ShapeNode was added to the new Diagram.
Best regards,
Cyrinael
