Normal Topic Performance when load a diagram (Read 2272 times)
CanadaProgrammer
Sep 8th, 2016 at 10:40pm
Because of some reasons, our team try to use our own format to storage diagram, instead of default format which you guys developed. Our format probably is like below:
<OurDiagram>
   <Nodes>
        <Node Caption="aaa" Width="300" Height="100" ...>
   </Nodes>
</OurDiagram>
So we need to load xml file first then get all and every node data to create node shape and append it to a diagram dynamically.  My question is on one same diagram maybe there are more than 10 thousand shapes. The loading performance is as same as the way which using default format file to load a diagram?
Re: Performance when load a diagram
Reply #1 - Sep 9th, 2016 at 11:28am
Your load times could be even faster if storing fewer properties and using serial XML API (XmlReader class) rather than DOM API (XmlDocument class). For tips on how to add objects dynamically as fast as possible, check the StressTest sample project.
CanadaProgrammer
Reply #2 - Sep 9th, 2016 at 5:13pm
