Normal Topic Mindfusion Typescript: AbstractionLayer.CreateControl support? (Read 3271 times)
Jeetendra
Oct 24th, 2016 at 6:24am
I am trying to to use a trial version of Mindfusion Typescript in my application and testing to generate flowchart example.
It doesn't have support for AbstractionLayer.createControl(this.Diagram, null, null, null, this.diagramElement)
is it only available on license copy?
Please help me to understand so that we can plan our purchase.
Thank you.
Jeetendra
Jeetendra Kumawat
Re: Mindfusion Typescript: AbstractionLayer.CreateControl support?
Reply #1 - Oct 24th, 2016 at 7:46am
You can use Diagram's static create(domElement) method instead, this one from .ts file -
	/** The Diagram class represents a flow diagram. */
	class Diagram extends MindFusion.Drawing.Canvas
		/** Creates and initializes a new Diagram associated with specified Canvas DOM element.
		 * @param element The Canvas DOM element that the Diagram should be attached to.
		 * @return A Diagram instance.
		static create(element: any): Diagram;
« Last Edit: Oct 24th, 2016 at 9:45am by Slavcho »
Jeetendra
Reply #2 - Oct 24th, 2016 at 8:13am
Hi Slavcho,
thank you for your reply.
I am actually trying to replicate "MindFusion JsDiagram Sample - FlowCharter" example in my angular2 App.
Is that possible to generate sample with trial version of .js and .d.ts files in angular2 App?
Jeetendra
Jeetendra Kumawat
Reply #3 - Oct 24th, 2016 at 9:56am
Hi Jeetendra,
Sure, everything you can do with JavaScript + JQuery you can also replicate in TypeScript + Angular. Calling the diagramming API as shown in flowcharter sample but from Angular controller or component should not change things that much.
