Hot Topic (More than 10 Replies) Problem display ShapeNode as a custom shape, not working (Canvas Mode) (Read 10222 times)
CrushJelly
Oct 24th, 2016 at 2:18pm
I try to draw ShapeNode, that has a custom Shape (ex . Rounded rectangle).
ShapeNode.Shape = new Shape(...);
It's not working, seems that every shape is picked from the Mindfusion library, I can't even adjust shapes size.
Doe's the trial version not allow to draw custom shapes or I am just missing something?
Re: Problem display ShapeNode as a custom shape, not working (Canvas Mode)
Reply #1 - Oct 25th, 2016 at 7:52am
It allows it, but in Canvas mode you must save custom shapes in a shape library file and assign it to the ShapeLibraryLocation property.
CrushJelly
Reply #2 - Oct 25th, 2016 at 2:59pm
Slavcho wrote on Oct 25th, 2016 at 7:52am:
I created library and attached it. But it doesn't work, I tried to debug and I saw that it load the shape, but i just see plain old Rounded rectangle and not my custom rectangle.
My .cs code:
diagramView.ShapeLibraryLocation = @"C:\Temp\test.shl";
ShapeNode shape = new ShapeNode();
shape.Shape = Shape.FromId("MyRectangle");
nodeListView.AddNode(shape, "Test");
Library:
<?xml version="1.0" encoding="utf-8"?>
<shapes version="2">
  <shape id="MyRectangle" fill-mode="Winding" display-name="MyRectangle">
    <outline>
      <round-rectangle dash-style="Custom" width="-1" x="14" y="40" w="80" h="40" r="15" />
    </outline>
    <decorations />
    <shape-decorations />
    <enable-outline>True</enable-outline>
  </shape>
</shapes>
And I'm adding picture of the diagram what I see.
I don't understand what is the problem.
Reply #3 - Oct 26th, 2016 at 8:17am
Set ShapeLibraryLocation from the aspx markup, assigning a relative url to it. Then DiagramView.OnInit will load the shape library automatically if MapPath can find the file (otherwise you'd need to call ShapeLibrary.LoadFrom(absolutePath) on server before using the shape). The URL is also transferred via JSON to let the client script load it automatically too, so you'll need to publish the file with your web server.
CrushJelly
Reply #4 - Oct 27th, 2016 at 8:04am
Slavcho wrote on Oct 26th, 2016 at 8:17am:
Well I tried this method ShapeLibrary.LoadFrom(absolutePath) and in debug mode I see that it loads the shape outline template (look picture. 2).
But still I see just a plain old rectangle.
My code:
ShapeLibrary.LoadFrom(@"C:\Temp\test.shl");
shape.Shape = Shape.FromId("MyEllipse"); // In debug mode I see that it loads
nodeListView.AddNode(shape, "MyEllipseNode");
Reply #5 - Oct 27th, 2016 at 8:11am
This will be enough to show the shape only in ImageMap mode, which draws on server side. In Canvas mode you must set ShapeLibraryLocation to load shape definitions on client side too - you can assign a relative URL from aspx file to it, which will let you use the shapes both from client and server sides without having to call ShapeLibrary.load methods.
CrushJelly
Reply #6 - Oct 27th, 2016 at 8:50am
Slavcho wrote on Oct 27th, 2016 at 8:11am:
Ok I did that, is this correct?,
If yes I still get the same result, it loads the template, but shoes rectangle, maybe I need to set some property
<ndiag:DiagramView
                            ID="diagramView"
                            runat="server"
                            ClientSideMode="Canvas"
                            JsLibraryLocation="../../Scripts/MindFusion/MindFusion.Diagramming.js"
                            [b]ShapeLibraryLocation="~/Workflow/Designer/Dependencies/test.shl"[/b]
                            style="position: absolute; left: 201px; top: 0px; right: 0px; bottom: 0px;">
                            <Diagram GridStyle="Lines" AlignToGrid="True" ShowGrid="True" GridColor="#1B000000" GridSizeY="10" GridSizeX="10"></Diagram>
                        </ndiag:DiagramView>
Reply #7 - Oct 27th, 2016 at 10:47am
It seems recent versions of Visual Studio's web server do not serve shl-extension files, changing it to xml loads correctly for me -
ShapeLibraryLocation="~/Workflow/Designer/Dependencies/test.xml"
Also note that the coordinates in shape library specify percentage, so the shape fills only a portion of its bounding rectangle when you set Y and Height to 40.
CrushJelly
Reply #8 - Oct 27th, 2016 at 12:04pm
Slavcho wrote on Oct 27th, 2016 at 10:47am:
Cant you show me a snap of your ShapeNode creation code?, because it didn't work for me, I changed to xml, but nothing happend
Reply #9 - Oct 27th, 2016 at 12:57pm
I used your code but with different shape id, which was in shl file you posted above -
var diagram = diagramView.Diagram;
if (!IsPostBack)
    shape.Shape = Shape.FromId("MyRectangle"); // In debug mode I see that it loads
    nodeListView.AddNode(shape, "MyRectangle");
Maybe also try to enter url to shape library in the browser to verify it's being served.
CrushJelly
Reply #10 - Oct 28th, 2016 at 8:24am
Slavcho wrote on Oct 27th, 2016 at 12:57pm:
if (!IsPostBack)
Something must be different, because I changed shl file to xml, and the server serves the file, but still I see the same shape.
Maybe there are other settings that I need to set, do I need anything for the NodeListView?
Maybe it's the problem that I am using trial version?
Reply #11 - Oct 28th, 2016 at 12:12pm
Does it work if you add this script to the aspx file?
<script type="text/javascript">
	Sys.Application.add_init(function ()
		MindFusion.Diagramming.Shape.loadFromLibPending = true;
</script>
By looking at the code I think the NodeListView might not refresh correctly if it's defined before the DiagramView. If that's the problem really, that script should refresh it once the DiagramView's library loads.
CrushJelly
Reply #12 - Oct 28th, 2016 at 1:02pm
Slavcho wrote on Oct 28th, 2016 at 12:12pm:
</script>
It works! Thank you!
Yep, it didn't work because it was defined before DiagramView, but with a script it works without changing definition places, I tried changing the definition places and it worked without script.
