Normal Topic After version update serialization on ContainerNode fails (Read 8453 times)
CrushJelly
Dec 6th, 2016 at 10:07am
After update to 5.7v, Container node serialization fails in older version it worked fine, but now get
"object not set to an instance of an object" error.
I debuged the code and I saw that ContainerNode is initialized and it is not null.
Maybe in the new version serialization changed, or I need to set all the properties?
Re: After version update serialization on ContainerNode fails
Reply #1 - Dec 6th, 2016 at 10:37am
Is this when saving files, or posting the page from client to server? Please post the exception's stack frame.
CrushJelly
Reply #2 - Dec 6th, 2016 at 10:56am
Slavcho wrote on Dec 6th, 2016 at 10:37am:
It's when loading Diagram.
Here is StackTrace:
PS. I adjusted paths in this StackTrace string.
System.NullReferenceException was unhandled by user code
  Message=Object reference not set to an instance of an object.
  Source=MindFusion.Diagramming.WebForms
  StackTrace:
       at MindFusion.Diagramming.WebForms.ContainerNodeConverter.Serialize(Object obj, JavaScriptSerializer serializer)
       at .MyContainerNodeConverter.Serialize(Object obj, JavaScriptSerializer serializer) in \MyContainerNodeConverter.cs:line 40
       at System.Web.Script.Serialization.JavaScriptSerializer.SerializeValue(Object o, StringBuilder sb, Int32 depth, Hashtable objectsInUse, SerializationFormat serializationFormat)
       at System.Web.Script.Serialization.JavaScriptSerializer.SerializeEnumerable(IEnumerable enumerable, StringBuilder sb, Int32 depth, Hashtable objectsInUse, SerializationFormat serializationFormat)
       at System.Web.Script.Serialization.JavaScriptSerializer.SerializeValueInternal(Object o, StringBuilder sb, Int32 depth, Hashtable objectsInUse, SerializationFormat serializationFormat)
       at System.Web.Script.Serialization.JavaScriptSerializer.SerializeDictionary(IDictionary o, StringBuilder sb, Int32 depth, Hashtable objectsInUse, SerializationFormat serializationFormat)
       at System.Web.Script.Serialization.JavaScriptSerializer.Serialize(Object obj, StringBuilder output, SerializationFormat serializationFormat)
       at System.Web.Script.Serialization.JavaScriptSerializer.Serialize(Object obj)
       at A.c11941951d1a217fe413d2aa0601bfabd.c9ae54d4cf6e8dfc48963e271f4f702cf(DiagramView c5c59c6a4a2a6c4948790bb75e068d36f)
       at A.c11941951d1a217fe413d2aa0601bfabd.c00fc1112717cfb59d7e43625eec0e867(DiagramView c3d2ea328bcae2cddab9c206fcedee40b, HtmlTextWriter c524c2562131a57a50f76b26b267fbde6)
       at System.Web.UI.WebControls.WebControl.Render(HtmlTextWriter writer)
       at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children)
       at System.Web.UI.HtmlControls.HtmlForm.RenderChildren(HtmlTextWriter writer)
       at System.Web.UI.HtmlControls.HtmlForm.Render(HtmlTextWriter output)
       at System.Web.UI.HtmlControls.HtmlForm.RenderControl(HtmlTextWriter writer)
       at System.Web.UI.Page.Render(HtmlTextWriter writer)
       at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Reply #3 - Dec 6th, 2016 at 11:32am
Are you passing non-null DiagramView reference to the converter when registering it and when calling base constructor?
CrushJelly
Reply #4 - Dec 6th, 2016 at 12:12pm
Slavcho wrote on Dec 6th, 2016 at 11:32am:
Yes. It previously worked.
Reply #5 - Dec 6th, 2016 at 12:44pm
This is ContainerNodeConverter's code, check if the arguments you are passing to it are non-null and maybe verify node.CaptionFormat is != null; ContainerNode's constructor always sets the latter.
public override IDictionary<string, object> Serialize(object obj, JavaScriptSerializer serializer)
    serializer.RegisterConverters(new JavaScriptConverter[] { new SizeConverter() });
    IDictionary<string, object> json = base.Serialize(obj, serializer);
    ContainerNode node = (ContainerNode)obj;
    if (view == null || view.ClientSideMode == ClientSideMode.Canvas)
        if (view == null)
            json.Add("type", node.GetType().ToString());
        json.Add("text", node.Caption);
        json.Add("captionHeight", node.CaptionHeight);
	json.Add("captionBackBrush", node.CaptionBackBrush);
	json.Add("textAlignment", node.CaptionFormat.Alignment);
	json.Add("lineAlignment", node.CaptionFormat.LineAlignment);
        json.Add("margin", node.Margin);
        json.Add("foldable", node.Foldable);
        json.Add("folded", node.Folded);
        json.Add("unfoldedSize", node.UnfoldedSize);
        json.Add("clipChildren", node.ClipChildren);
        json.Add("allowAddChildren", node.AllowAddChildren);
        json.Add("allowRemoveChildren", node.AllowRemoveChildren);
        json.Add("shape", node.Shape);
I can't see anything else that could throw NullReferenceException.
CrushJelly
Reply #6 - Dec 6th, 2016 at 1:33pm
Slavcho wrote on Dec 6th, 2016 at 12:44pm:
        if (view == null)
I have old xml that is created in silvelight. "<Diagram Version="12">", would that be an issue, maybe there is new properties, that we need to set?
Reply #7 - Dec 6th, 2016 at 1:48pm
Please attach it here zipped or email to support@mindfusion.eu
CrushJelly
Reply #8 - Dec 6th, 2016 at 2:01pm
Slavcho wrote on Dec 6th, 2016 at 1:48pm:
Found solution. Just applied styling and other properties after xml load, because, not all properties set in old xml version.
« Last Edit: Dec 7th, 2016 at 6:49am by CrushJelly »
