Normal Topic Programmatically Draw Links Between Anchors (Read 2301 times)
alukes
Jan 19th, 2017 at 2:26pm
I need to capture the end points of a link when a user creates a link or when they move a node. Later I use that information to programmatically draw the links.
Is it possible to obtain the source and destination anchor index and later use that information to draw the link?
Re: Programmatically Draw Links Between Anchors
Reply #1 - Jan 19th, 2017 at 5:31pm
If you use anchor points, you can get and restore indices using these DiagramLink methods (they are marked as @private by mistake and not imported in help file, we'll fix for next release) -
getOriginAnchor: function ()
setOriginAnchor: function (index)
getDestinationAnchor: function ()
setDestinationAnchor: function (index)
If you don't use anchor points, try get/setStartPoint and get/setEndPoint methods.
alukes
Reply #2 - Jan 20th, 2017 at 4:52am
That works. Great support as usual.
