Normal Topic Loading Custom Shape from XML File (Read 4289 times)
Viev
Feb 2nd, 2017 at 12:15am
Hi there,
If I save a diagram to XML (using the SaveToXML method) and a Node has a custom shape, only the "Id" of the Shape is stored in the respective [Node] element of the XML, not the Shape definition/template.
Quite obviously, when I then go to load the XML document (using the LoadFromXML method) I get the error "Failed to open document!"....because the loader can't match the "Id" of the Node to a Shape definition/template.
Let's say that the "Id" of my node is "ShapeId123"....my question is
"How can I make the loader match that Node Id to a respective Shape definition/template within the software loading the XML document?".
Please note...I have no problem saving and retrieving the Shape definition using the "SaveTo" and "FromXMLElement" methods....I just don't know how to link the loading of an XML file (with only "Ids" for Nodes) to a Shape definition loaded from XML (FromXMLElement).
Any assistance most welcome.
Thanking you in advance,
Victor
Re: Loading Custom Shape from XML File
Reply #1 - Feb 2nd, 2017 at 9:10am
The control expects all shapes to be defined and registered by id at startup time, so when loading a file it can find the shape by id. Its versions for some other platforms raise a ShapeNotDefined event when it cannot find shape definition for id - we could implement it in Windows Forms too if you prefer to load custom shape definitions on demand instead of pre-defining them all.
Another possibility is to use the SaveToXml(XmlDocument) method, and append your own <Shapes> element containing shape definitions. Then when loading files you could first parse and register the shapes and the call LoadFromXml(XmlDocument).
Reply #2 - Feb 2nd, 2017 at 1:21pm
This build adds a ShapeNotDefined event you could handle as below -
https://mindfusion.eu/_beta/fcnet_shpevt.zip
diagram.ShapeNotDefined += (s, a) =>
	if (a.UnknownId == "custom")
		a.Shape = new Shape(
			Shapes.Decision.Outline, FillMode.Winding, "custom");
diagram.LoadFromXml("test.xml");
Viev
Reply #3 - Feb 3rd, 2017 at 1:10am
Hi Slavcho,
Thank you for your reply. That helps understand "why". I just need information as to "how"....
How do I "define and register by id" the shape/s at startup time?....that's the bit I'm missing.
I know how to define a shape...but I don't know how to "register by id" the shape so that it is registered with the control ("at startup time").
That's the missing link for me.
Any information most welcome.
kind regards,
Victor
Reply #4 - Feb 3rd, 2017 at 6:22am
Calling constructors with Id argument is enough; pre-loading a shape library file where shapes have associated identifiers should work too.
Viev
Reply #5 - Feb 5th, 2017 at 11:48pm
Hi Slavcho,
That worked.
Anybody else reading this thread can also look at the following thread for more information....
http://mindfusion.eu/Forum/YaBB.pl?num=1184853723/10
kind regards,
Victor
