Normal Topic Using link animation in a Windows form application (Read 2487 times)
davidl
Jan 14th, 2017 at 3:43pm
There is an excellent silverlight sample app posted here that shows how to animate a DiagramLink:
http://mindfusion.eu/Forum/YaBB.pl?num=1301505202/0#8
I have not been able to port this code to a Windows From app (my storyboard experience is light). Can you provide a sample windows forms project showing how to animate a link?
Thanks, David
Re: Using link animation in a Windows form application
Reply #1 - Jan 16th, 2017 at 7:50am
Hi!
Here's how you could implement it in Windows Forms -
https://mindfusion.eu/_samples/linkanimation_winforms.zip
class LinkAnimator
	public LinkAnimator(DiagramLink link, DiagramView view)
		this.link = link;
		this.view = view;
	public void AnimatePath(
		int animationLength,
		params PointF[] points)
		if (points.Length < 2)
			return;
		// total length of specified path
		float pathLen = Enumerable.
			Range(0, points.Length - 1).
			Aggregate(0f, (len, index) =>
				Utilities.Distance(points[index], points[index + 1]));
		// prepare the link
		link.ControlPoints.Clear();
		link.ControlPoints.Add(points[0]);
		// animate from a thread
		var animationThread = new Thread(
				for (int s = 0; s < points.Length - 1; s++)
					// how much to grow the segment for each animation frame
					var segment = new Vector(points[s], points[s + 1]);
					float segmentTime = animationLength * segment.Length / pathLen;
					var increment = segment * FrameLen / segmentTime;
					// frames for current segment
					for (int f = 0; f < segmentTime / FrameLen; f++)
						Thread.Sleep(FrameLen);
						link.EndPoint = link.EndPoint + increment;
						view.Invoke(new Action(
							() => link.UpdateFromPoints()));
					// set exact position in case animation hasn't reached it due to rounding
					if (link.EndPoint != points[s + 1])
						link.EndPoint = points[s + 1];
					// add next point
					if (s < points.Length - 2)
						link.ControlPoints.Add(points[s + 1]);
		animationThread.Start();
	DiagramLink link;
	DiagramView view;
	const int FrameLen = 1000 / 30; // in milliseconds
diagram.LinkShape = LinkShape.Polyline;
var n1 = diagram.Factory.CreateShapeNode(10, 10, 20, 20);
var n2 = diagram.Factory.CreateShapeNode(210, 10, 20, 20);
var n3 = diagram.Factory.CreateShapeNode(10, 110, 20, 20);
var n4 = diagram.Factory.CreateShapeNode(210, 110, 20, 20);
var l1 = diagram.Factory.CreateDiagramLink(n1, n2);
var l2 = diagram.Factory.CreateDiagramLink(n3, n4);
new LinkAnimator(l1, diagramView).
    AnimatePath(2000,
        l1.StartPoint,
        new PointF(70, 10),
        new PointF(130, 30),
        l1.EndPoint);
new LinkAnimator(l2, diagramView).
    AnimatePath(1000, l2.StartPoint, l2.EndPoint);
Code above assume link shapes with two control points per segment, you'll need to extend it if you want to use with Bezier links. Also if you are with older version of the control, you'll need to call UpdateFromPoints overload that takes updateSegmentCount argument; latest one does not require that.
