Normal Topic WPF Scheduling: Item background depending on Appointment data (Read 6650 times)
Heli
Feb 23rd, 2017 at 9:43am
I have my own Appointment class (derived from MindFusion.Scheduling.Appointment).
I'm using Theme Light.
I'd like to have the item background drawn with the color my Appointment class holds:
public System.Windows.Media.Brush Background { get; set; }
I'm afraid something like that won't work:
<planner:Calendar.ItemSettings>
    <planner:ItemSettings>
        <planner:ItemSettings.CalendarStyle>
            <planner:CalendarStyle Background="{Binding ???}" />
            </planner:ItemSettings.CalendarStyle>
    </planner:ItemSettings>
</planner:Calendar.ItemSettings>
Same question applies to Xamarin.Scheduling, how to do it there?
Heli
Re: WPF Scheduling: Item background depending on Appointment data
Reply #1 - Feb 23rd, 2017 at 1:08pm
You should either create a custom item viewer for your appointments or use custom drawing and use the custom property to paint your items' background.
Heli
Reply #2 - Feb 23rd, 2017 at 1:40pm
I guess, custom item viewer is something like in the sample "Scheduling.CustomItemTemplates"?
Maybe you can provide me the app.xaml contents like
<Style TargetType="{x:Type local:MyAppointmentPresenter}">
but based on Theme Light design.
And is there a sample for the second option, custom drawing, too?
Heli
Reply #3 - Feb 23rd, 2017 at 4:11pm
The CustomItemTemplates sample illustrates exactly what you need, but its a lot of work to change the background of the item when you can simply use the item's Style for this purpose. Anyway, check the modified sample:
https://mindfusion.eu/_temp/_sample_CustomItemTemplates.zip
Heli
Reply #4 - Feb 23rd, 2017 at 4:26pm
thank you for this sample, that's great!
Quote:
...you can simply use the item's Style for this purpose.
So, there is a much simplier way to set the appointment item background color depending on data stored in MyAppointment object?
Most probably I think too complicated, but I don't get it, sorry.
How can I achieve a data dependent appointment/item background the easiest way? Suitable for WPF and Xamarin.Scheduling.
Can you create a small sample, please?
At this point, I'd like to thank you for your great support.
You helped me a lot so far!
Heli
« Last Edit: Feb 23rd, 2017 at 9:35pm by Heli »
Reply #5 - Feb 24th, 2017 at 8:58am
Check out this modified sample: https://mindfusion.eu/_temp/_sample_CustomItemTemplates2.zip.
The items no longer have custom presenters. Instead, when the state of an item changes (in response to a click for example), the item background is changed through its style. The style is associated with the item through the Calendar.SetItemStyle method.
Heli
Reply #6 - Feb 24th, 2017 at 12:02pm
now I got your point.
I applied this idea to my application by holding a reference to the Calendar object within MyAppointment (data backing class). An event notifies MyAppointment about possible reference changes.
So, whenever a data property changes which should influence the UI (i.e. background color change), I set the style as you showed in the example within the MyAppointment property setter.
That works for me.
Thank you!
Heli
