Normal Topic Link Performance (Read 2672 times)
38Mikes
Link Performance
Feb 27th, 2017 at 2:18am
Having performance issues with the DiagramLink object.  My diagram has thousands of nodes.  I add all of the nodes (which are SvgNode) to the diagram first, and this happens reasonably fast, just a few seconds.  When I then add the links, about 1800 of them, it takes literally 20+ minutes.  I've identified the primary bottleneck to be the following line of code.
var link = diagram.Factory.CreateDiagramLink((DiagramNode)oNode, (DiagramNode)dNode);
This particular line, instantiation of the DiagramLink object, takes about 600ms.  Times thousands it gets pretty ridiculous.  How do I speed this up?  Thanks.
38Mikes
Re: Link Performance
Reply #1 - Feb 27th, 2017 at 2:30am
Note, I have also tried removing the diagram from the view, adding all the nodes + links, then adding back to the view, makes no difference at all.
Reply #2 - Feb 27th, 2017 at 8:33am
Try setting Diagram.ValidityChecks = false. If using links' AutoRoute property, also call the Suspend and Resume methods of Diagram.LinkRouter around the code that creates links.
