Normal Topic Tooltip on Anchor is not shown (Read 2237 times)
Dominic_
Mar 1st, 2017 at 10:23am
I downloaded the Anchor Points Sample [mindfusion.eu/samples/wpf/diagram/Anchors.CS.zip] and modified the anchor points to have a tooltip:
new AnchorPoint(50, 0, true, true) {ToolTip = "tool1" }
But the tooltip is not displayed. Only tooltips on the entire node (with ShapeNode.ToolTip) are visible.
In another post [mindfusion.eu/Forum/YaBB.pl?num=1327482189], a custom tooltip is implemented. That might be a work-around, but I'd prefer using the built-in tooltip.
Dominic
Re: Tooltip on Anchor is not shown
Reply #1 - Mar 1st, 2017 at 11:30am
Right, in WPF we rely on Tooltip property inherited from FrameworkElement (base of DiagramItem) appearing automatically. AnchorPoint does not derive from FrameworkElement so we'll need to add some special handling for it, we'll try to implement it in next few days.
Reply #2 - Mar 2nd, 2017 at 3:06pm
AnchorPoint.ToolTip should show correctly with this build -
https://mindfusion.eu/_beta/wpfdiag_aptips.zip
