Normal Topic WPF Scheduling: Timetable header styling for today, expand current item (Read 5633 times)
Heli
Mar 1st, 2017 at 4:37pm
two questions regarding Timetable view:
1.) I'd like to style the header (showing the date of the current day) to have a golden background when current day is today.
In List and (Single)Month views, there is something like
ShowToday="True" TodayFillBrush="Gold"
The only possibility I see would be to write a converter which delivers gold color for the current day and default color for any other day.
Is there an easier way?
2.) Whe dragging an item (appointment) with duration > 30 min., the item is shown "collapsed" to a 30 minute unit height. How can I force the item to keep its height, so I can read the contents and see its extents while dragging?
When dropped at a valid place, it stays collapsed there (until redraw/refresh).
When dropped at an invalid place, it jumps back to where dragging started and is shown with full height (= good).
Heli
Re: WPF Scheduling: Timetable header styling for today, expand current item
Reply #1 - Mar 2nd, 2017 at 9:30am
The attached sample demonstrates how to customize the header of a timetable column by using a custom template (through the TimetableSettings.ColumnHeaderTemplate property).
Regarding the second point, I'm not sure what you mean. I cannot reproduce dragging where the item height is reduced from the original size. Please, provide more details or an image illustrating the problem.
Sample.zip (Attachment deleted)
Heli
Reply #2 - Mar 2nd, 2017 at 10:33am
Regarding point 2: See pictures; number 1 shows the full size appointment before dragging, number 2 shows the collapsed representation during/after dragging.
Reply #3 - Mar 2nd, 2017 at 12:12pm
What settings do you use for the calendar control when this happens? A small sample demonstrating the issue will be appreciated.
Heli
Reply #4 - Mar 9th, 2017 at 9:44am
I set EnableSnapping to false/disable as suggested, now it works.
Thank you!
Heli
