Hot Topic (More than 10 Replies) Need to draw similar kind of component in angular2 shown in pic (Read 10109 times)
Re: Need to draw similar kind of component in angular2 shown in pic
Reply #15 - Mar 22nd, 2017 at 2:13pm
If you need that for the whole diagram, set its Behavior property to DoNothing. If you need it for individual nodes, set their Locked property to true.
Reply #16 - Mar 28th, 2017 at 2:09pm
Try updated scripts and .ts here -
https://mindfusion.eu/_beta/typescript_customdraw.zip
1. The definition file now lets you do custom drawing from Typescript instead of using attached nodes, which should give you better performance -
function onUpdateVisuals(item: MindFusion.Diagramming.DiagramItem): void
 var rect = item.bounds;
 var rectPath = new MindFusion.Drawing.Path();
 rectPath.addRect(rect.x + 2, rect.y + 2, 6, rect.height - 4);
 rectPath.setPen("#FF0000");
 rectPath.setBrush("orange");
 item.getGraphicsContent().push(rectPath);
 var trianglePath = new MindFusion.Drawing.Path();
 trianglePath.moveTo(rect.x + 10, rect.y + rect.height / 2);
 trianglePath.lineTo(rect.x + 30, rect.y + rect.height / 2);
 trianglePath.lineTo(rect.x + 20, rect.y + rect.height / 2 + 10);
 trianglePath.lineTo(rect.x + 10, rect.y + rect.height / 2);
 trianglePath.close();
 trianglePath.setPen("FF0000");
 trianglePath.setBrush("transparent");
 item.getGraphicsContent().push(trianglePath);
 var nodeText = new MindFusion.Drawing.Text("text", new MindFusion.Drawing.Rect(rect.x + rect.width, rect.y, 20, 20));
 nodeText.setFont(new MindFusion.Drawing.Font("sans-serif", 4, false, true, false));
 item.getGraphicsContent().push(nodeText);
MindFusion.Diagramming.ShapeNode.prototype.onUpdateVisuals = onUpdateVisuals; // or instance.onUpdateVisuals = onUpdateVisuals;
2. You can find ContainerNode.setFoldIconSize method that lets you assign fixed size to the fold icon so it won't fill your larger caption bars.
