Normal Topic once ruler measurements change canvas object size change proportionality (Read 3326 times)
kelum
May 13th, 2017 at 9:00am
I added mindfusion ruler for wpf canvas, now once I change the measurement type MM to INCH its not change the nodes sizes that loaded in the canvas
Online
Re: once ruler measurements change canvas object size change proportionality
Reply #1 - May 15th, 2017 at 1:18pm
Ruler.Unit is independent from Diagram.MeasureUnit and the ruler scales can display measures in different units than diagram's. You could assign your own ContextMenu instance to Ruler.ContextMenu, with menu items that change both ruler's and diagram's unit if that's what you need.
kelum
Reply #2 - May 15th, 2017 at 4:36pm
How can I configure this to, once I change ruler's measurement type, change the diagram object's measurement sizes ?
Online
Reply #3 - May 17th, 2017 at 7:03am
You can create your own menu like this -
ruler.ContextMenu = new ContextMenu();
var inchItem = new MenuItem { Header = "Inch" };
inchItem.Click += (s, e) =>
	diagram.MeasureUnit = GraphicsUnit.Inch;
	ruler.Unit = RulerUnit.Inch;
ruler.ContextMenu.Items.Add(inchItem);
Percents' unit does not work for the diagram but only for ruler (showing percentage from diagram's Bounds) so you'll need to skip it from the menu.
