Normal Topic Update to Angular 4 breaks the diagram (Read 2274 times)
Shafi
May 17th, 2017 at 2:59pm
We updated our code from Angular2 to Angular4, but the Mindfusion diagram-libary did not respond well to the update. The nodes fail to load show up properly. Please see image attached. Also there is an error thrown on console in dev tools.
Quote:
ERROR DOMException: Failed to execute 'drawImage' on 'CanvasRenderingContext2D': The HTMLImageElement provided is in the 'broken' state.
at MindFusion.Drawing.Image.draw (eval at <anonymous> (eval at webpackJsonp.56.module.exports (http://localhost:10050/scripts.bundle.js:1:1)), <anonymous>:1:63075)
at mdraw.Container.Container.draw (eval at <anonymous> (eval at webpackJsonp.56.module.exports (http://localhost:10050/scripts.bundle.js:1:1)), <anonymous>:1:56810)
at b.Diagram.repaint (eval at <anonymous> (eval at webpackJsonp.56.module.exports (http://localhost:10050/scripts.bundle.js:1:1)), <anonymous>:1:38937)
at proxy (eval at webpackJsonp.32.module.exports (http://localhost:10000/scripts.bundle.js:1:1), <anonymous>:496:14)
at ZoneDelegate.invokeTask (http://localhost:10050/vendor.bundle.js:128529:31)
at Object.onInvokeTask (http://localhost:10050/vendor.bundle.js:4478:37)
at ZoneDelegate.invokeTask (http://localhost:10050/vendor.bundle.js:128528:36)
at Zone.runTask (http://localhost:10050/vendor.bundle.js:128296:47)
at ZoneTask.invoke (http://localhost:10050/vendor.bundle.js:128591:38)
at timer (http://localhost:10050/vendor.bundle.js:129606:29)
defaultErrorLogger @ vendor.bundle.js:1443
Re: Update to Angular 4 breaks the diagram
Reply #1 - May 17th, 2017 at 3:45pm
Your migration might have changed the image URLs, see if the browser shows the image you are trying to draw if you paste image URL in the address bar.
