Normal Topic Print the WPF window that include MindFusion Diagram (Read 1679 times)
kelum
May 23rd, 2017 at 2:22pm
I have few grids with Mindfusion Canvas, I'm trying to print whole WPF window (which is <Grid x:Name="TotalGrid">)
this is the the window I want to print
<Window x:Class="Sample.Layout.PrintPreviewPopUp"
        xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
        xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
        xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
        xmlns:local="clr-namespace:Sample.Layout"
        xmlns:diag="http://mindfusion.eu/diagramming/wpf"
        mc:Ignorable="d"
        Title="PrintPreviewPopUp" Height="4675.333" Width="1452.001">
        <Grid.RowDefinitions>
            <RowDefinition Height="50"/>
            <RowDefinition Height="*"/>
        </Grid.RowDefinitions>
           <ScrollViewer HorizontalScrollBarVisibility="Auto" Margin="0,68,16,0" Grid.Row="1">
                <local:GridControl ShowCustomGridLines="True"
              GridLineBrush="#000000"
              GridLineThickness="1" Width="1385" Height="4611">
                    <local:GridControl.RowDefinitions>
                    </local:GridControl.RowDefinitions>
              GridLineThickness="1" HorizontalAlignment="Left" Height="1313" Margin="0,3288,0,0" VerticalAlignment="Top" Width="1004">
                        <local:GridControl.ColumnDefinitions>
                            <ColumnDefinition Width="282*"/>
                            <ColumnDefinition Width="215*"/>
                            <ColumnDefinition Width="260*"/>
                            <ColumnDefinition Width="237*"/>
                        </local:GridControl.ColumnDefinitions>
                            <RowDefinition Height="49*"/>
                            <RowDefinition Height="1619*"/>
                        <TextBlock  local:GridControl.Row="0" local:GridControl.Column="0" Text="Machine Type" TextAlignment="Center" FontSize="18" />
                        <TextBlock  local:GridControl.Row="0" local:GridControl.Column="1" Text="Qty" TextAlignment="Center" FontSize="18" />
                        <TextBlock  local:GridControl.Row="0" local:GridControl.Column="2" Text="Needdle Size" TextAlignment="Center" FontSize="18" />
                        <TextBlock  local:GridControl.Row="0" local:GridControl.Column="3" Text="Qty" TextAlignment="Center" FontSize="18" />
                    </local:GridControl>
              GridLineThickness="1" HorizontalAlignment="Left" Height="1262" Margin="1009,3339,0,0" VerticalAlignment="Top" Width="376">
                            <ColumnDefinition Width="34*"/>
                            <ColumnDefinition Width="152*"/>
                            <ColumnDefinition Width="68*"/>
                            <ColumnDefinition Width="59*"/>
                            <ColumnDefinition Width="63*"/>
                            <RowDefinition Height="29*"/>
                            <RowDefinition Height="784*"/>
                        <TextBlock  local:GridControl.Row="0" local:GridControl.Column="1" Text="Color" TextAlignment="Center" FontSize="18" />
                        <TextBlock  local:GridControl.Row="0" local:GridControl.Column="2" Text="80" TextAlignment="Center" FontSize="18" />
                        <TextBlock  local:GridControl.Row="0" local:GridControl.Column="3" Text="120" TextAlignment="Center" FontSize="18" />
                        <TextBlock  local:GridControl.Row="0" local:GridControl.Column="4" Text="160" TextAlignment="Center" FontSize="18" />
                    <Label x:Name="label" BorderThickness="1" BorderBrush="Black" Content="Line Minimum Thread Requirement" HorizontalAlignment="Center" Margin="1009,3288,1,0" VerticalAlignment="Top" Width="375" Height="51" FontSize="18"/>
                    <Label x:Name="label1" Content="LAYOUT PRODUCT LINE" HorizontalAlignment="Left" Margin="681,10,0,0" VerticalAlignment="Top" Height="37" Width="280" RenderTransformOrigin="0.5,0.5" FontSize="24">
                    </Label>
                    <Label x:Name="label2" Content="STYLE : LSW15CT010/ESS16CT012" HorizontalAlignment="Left" Margin="10,43,0,0" VerticalAlignment="Top" RenderTransformOrigin="-8.456,0.756" Width="194" Height="26"/>
                    <Label x:Name="label3" Content="DESCRIPTION: METALAND" HorizontalAlignment="Left" Margin="906,43,0,0" VerticalAlignment="Top" Width="170" Height="26"/>
                    <Label x:Name="label4" Content="FO\CAS\IE\01\01" HorizontalAlignment="Left" Margin="1266,10,0,0" VerticalAlignment="Top" Width="109" Height="26"/>
              GridLineThickness="1" HorizontalAlignment="Left" Height="3082" Margin="0,74,0,0" VerticalAlignment="Top" Width="1385">
                            <ColumnDefinition Width="310*"/>
                            <ColumnDefinition Width="813*"/>
                            <ColumnDefinition Width="262*"/>
                            <RowDefinition/>
                        <ListBox Name="listNodes" local:GridControl.Row="0" local:GridControl.Column="0" Margin="10,10,10,189">
                            <ListBox.ItemTemplate>
                                <DataTemplate>
                                    <StackPanel Orientation="Vertical" Height="120" Width="280">
                                        <local:GridControl local:GridControl.Row="0" local:GridControl.Column="0"  Margin="0,10,10,2941" RenderTransformOrigin="0.5,0.5" HorizontalAlignment="Right" Width="268" Height="100" ShowCustomGridLines="True" GridLineBrush="#000000" GridLineThickness="1">
                                                <ColumnDefinition Width="79*"/>
                                                <ColumnDefinition Width="99*"/>
                                                <ColumnDefinition Width="90*"/>
                                                <RowDefinition Height="39*"/>
                                                <RowDefinition Height="63*"/>
                                            <TextBlock Grid.Row="0" Grid.Column="0"  Text="{Binding Text}"/>
                                            <TextBlock Grid.Row="0" Grid.Column="1"  Text="{Binding Brush}"/>
                                            <TextBlock Grid.Row="0" Grid.Column="2"  Text="{Binding Name}"/>
                                            <TextBlock Grid.Row="1" Grid.Column="0"  Text="{Binding Tag.Type}"/>
                                            <TextBlock Grid.Row="1" Grid.Column="1"  Text="{Binding Text}"/>
                                            <TextBlock Grid.Row="1" Grid.Column="2"  Text="{Binding Brush}"/>
                                            <TextBlock Grid.Row="2" Grid.Column="0"  Text="{Binding Name}"/>
                                            <TextBlock Grid.Row="2" Grid.Column="1"  Text="{Binding Tag.Type}"/>
                                            <TextBlock Grid.Row="2" Grid.Column="2"  Text="{Binding Name}"/>
                                    </StackPanel>
                                </DataTemplate>
                            </ListBox.ItemTemplate>
                        </ListBox>
                        <TextBlock  local:GridControl.Row="0" local:GridControl.Column="1" Text=" Customer : &#x0a; Line No :" TextAlignment="Left" FontSize="18" Margin="10,10,10,3024" />
                        <diag:Diagram local:GridControl.Row="0" local:GridControl.Column="1" Margin="10,58,10,1881" x:Name="diagram" ShowGrid="True" AutoResize="None" SerializeTag="siteMap_SerializeTag"
                 DeserializeTag="siteMap_DeserializeTag" NodeCreated="diagram_NodeCreated"/>
              GridLineThickness="1" HorizontalAlignment="Left" Height="177" Margin="0,2905,0,0" VerticalAlignment="Top" Width="310">
                                <ColumnDefinition Width="207*"/>
                                <ColumnDefinition Width="83*"/>
                                <RowDefinition Height="57*"/>
                                <RowDefinition Height="59*"/>
                                <RowDefinition Height="61*"/>
                            <TextBlock  local:GridControl.Row="0" local:GridControl.Column="0" Text=" SECTION TARGET PER HR" TextAlignment="Left" FontSize="15" />
                            <TextBlock  local:GridControl.Row="1" local:GridControl.Column="0" Text=" TOTAL SMV" TextAlignment="Left" FontSize="15" />
                            <TextBlock  local:GridControl.Row="2" local:GridControl.Column="0" Text=" BALENCING EFFICINCY" TextAlignment="Left" FontSize="15" />
              GridLineThickness="1" Grid.Column="2" HorizontalAlignment="Left" Height="177" Margin="0,2905,0,0" VerticalAlignment="Top" Width="262">
                                <RowDefinition Height="56*"/>
                                <RowDefinition Height="58*"/>
                                <ColumnDefinition Width="5*"/>
                                <ColumnDefinition Width="2*"/>
                            <TextBlock  local:GridControl.Row="0" local:GridControl.Column="0" Text=" NO OF OPERATORS" TextAlignment="Left" FontSize="15" />
                            <TextBlock  local:GridControl.Row="1" local:GridControl.Column="0" Text=" PREPARED BY" TextAlignment="Left" FontSize="15" />
                            <TextBlock  local:GridControl.Row="2" local:GridControl.Column="0" Text=" DATE/TIME" TextAlignment="Left" FontSize="15" />
              GridLineThickness="1" Grid.Column="1" HorizontalAlignment="Left" Height="177" Margin="0,2905,0,0" VerticalAlignment="Top" Width="813">
                            <Grid.ColumnDefinitions>
                                <ColumnDefinition Width="409*"/>
                                <ColumnDefinition Width="414*"/>
                            </Grid.ColumnDefinitions>
                                <RowDefinition Height="89*"/>
                                <RowDefinition Height="78*"/>
                            <TextBlock  local:GridControl.Row="0" local:GridControl.Column="0" Text=" Line Lth/(cm)" TextAlignment="Left" FontSize="15" />
                            <TextBlock  local:GridControl.Row="1" local:GridControl.Column="0" Text=" Line Width/(cm)" TextAlignment="Left" FontSize="15" />
            </ScrollViewer>
        <Button Name="Print" Content="PrintDiagram" Grid.Row="0" HorizontalAlignment="Left" Width="200"  Click="PrintButton_Click"/>
    </Grid>
</Window>
this is the window image, I'm trying to print
So I wrote following method in above WPF window codebehind file
private void PrintButton_Click(object sender, RoutedEventArgs e)
            PrintDialog printDialog = new PrintDialog();
            if (printDialog.ShowDialog() == true)
                printDialog.PrintVisual(TotalGrid, "Grid description");
Once I select above "Print" button Its directing to PrintVisual window and not print the whole wpf window.
what should I correct here.
Re: Print the WPF window that include MindFusion Diagram
Reply #1 - May 23rd, 2017 at 3:51pm
What do you mean by "its directing to PrintVisual window"? Your code worked well enough for printing root panel of my test app, attached shows result sent to virtual PDF printer. This method won't print off-screen parts of the diagram if that's what you expect, instead you'd need to call Diagram.Print method.
Grid_description.pdf (Attachment deleted)
