Normal Topic HitTestHandle can not be triggered in a polygon node! (Read 1892 times)
chowy
Jun 26th, 2017 at 9:37am
I drew a polygon,When the mouse moves to the green line or above the point, can not trigger AdjustmentHandle HitTestHandle (Point point); only when the mouse moves to the black line above, can trigger this method.What method can I use to trigger it?In Behavior I wrote this way:
            NodeItemBase nodeItemBase =
                        Diagram.GetNodeAt(mousePoint, NodeItemBase.CNEARNESSTHRESHOLD) as NodeItemBase;
            if (nodeItemBase == null || nodeItemBase is MousePointNode)
                return new Tuple<NodeItemBase, EHandleId>(null, handleId);
            NodeAdjustmentHandle adjustmentHandle = nodeItemBase.HitTestHandle(mousePoint) as NodeAdjustmentHandle;
Online
Re: HitTestHandle can not be triggered in a polygon node!
Reply #1 - Jun 26th, 2017 at 11:40am
I'm guessing GetNodeAt returns null when point is not inside the polygon and your code never gets to calling HitTestHandle. Apart from checking GetNodeAt result, standard behavior classes also call HitTestHandle on diagram.ActiveItem, so you could do that too from your custom behavior.
If only reason for derived behavior class is to let you draw nodes of custom types, note that you could implement that by setting diagram.Behavior = Custom and diagram.CustomNodeType = typeof(your node class) instead. If you have other reasons for creating custom behavior class, you could call base.StartDraw at some point to let the base class do hit-testing of existing items.
chowy
Reply #2 - Jun 27th, 2017 at 12:58am
Slavcho wrote on Jun 26th, 2017 at 11:40am:
Thanks!
