Normal Topic Visio Export library beta tests (Read 3613 times)
Aug 15th, 2005 at 10:52am
First beta version of the FlowChartX Visio export component is now available. The component creates Visio 2003 .vdx files (XML drawing files). If you are interested in trying it out, use the link below to get a copy:
https://mindfusion.org/_beta/fcx2visio.zip
Unzip the archive and use the regsvr32 utility to register the FcxVisioExport.dll as a COM module. Try to export any FlowChartX diagrams you have to Visio (the more complex they are, the better, for the purpose of the beta tests). If you encounter any bugs, please report them in this forum or email to support(DESPAM)@mindfusion.org.
The export library requires installation of FlowChartX Pro, and the final version will be included in the FlowChartX Pro package.
Re: Visio Export library beta tests
Reply #1 - Aug 27th, 2005 at 3:23pm
A new build of the Visio export library has been uploaded here:
It provides the following new features:
- exporting of ActiveX nodes (boxes of Style bsAxControl)
- a new property CreateVisioGroups specifies whether FlowChartX groups should be exported to Visio groups when possible
Reply #2 - Sep 1st, 2005 at 8:37am
Yet another build uploaded:
The dll now provides support for saving boxes with icons in Visio and for the FlowChartX "styled text" feature, i.e. text formatting should be preserved as close as possible when exported to Visio.
