Normal Topic Want a Visio 2003 like toolkit with source code (Read 4062 times)
kellyonlyone
Aug 30th, 2005 at 1:59am
Hi Support,
Currently,I want a Visio 2003 like toolkit,I had visited your website and ucancode software''s website,and I am considering between FlowChartX Pro and XD++ MFC Library,so I have the following two questions:
1.Can you help us to develop a XD++''s like toolbox bar with drag and drop features?
2.Does your product ships with full source code,if so,what''s the cost? is there any projects limit.
3.We want to add some new style shapes,does this can also be developed with FlowChartX.
XD++ MFC Library can be found by: http://www.ucancode.net
I am waiting for your response!,if it is possible,I will purchase it as soon as possible.
Thanks!
Re: Want a Visio 2003 like toolkit with source cod
Reply #1 - Aug 30th, 2005 at 11:07am
This can be done using a second FlowChartX instance. Check out the Palette sample, which is available in MFC and VB, for an example how to implement it.
Yes, you can purchase the source code for additional $450. It is in C++ and is based on the ATL and WTL libraries. There are not limits on the projects you can use the control, as long as they are not competitive to FlowChartX, i.e. diagramming controls.
Yes, use the ShapeTemplate class to define new shapes. You might use the shape designer tool to create the source code for a shape definition:
https://mindfusion.org/FcxDesignerBeta.zip
I hope this helps,
« Last Edit: Oct 18th, 2006 at 4:37am by Stoyo »
kellyonlyone
Reply #2 - Oct 17th, 2006 at 11:09pm
I want to convert a few files (That I draws with Visio 2003 before) to flowchartx, is it possible?
If it is yes, any additional charge needed?
Reply #3 - Oct 18th, 2006 at 4:44am
You could use the VisioImport library, which is available for download here:
http://www.mindfusion.org/download.html
The import library is free, but requires the Pro edition of FlowChartX. It can import Visio 2003 XML Drawing files (*.vdx).
kellyonlyone
Reply #4 - May 24th, 2007 at 6:36am
Sorry to trouble you again, sir.
Do I need any additional charge for the source code of this "VisioImport library"? I already have the flowchartx.
Reply #5 - May 24th, 2007 at 9:05am
Usually we do not distribute the VisioImporter source code. However I guess if you have a FlowChartX license with source code, we can give you the VisioImporter code too. Email me your order ID and I will send you back the project files.
